coyotesfan9898
May 01, 2018Explorer
Yes, the trailer is level. I assume it’s running. When I first went through it I noticed the 5amp fuse on the circuit board was blown and was cause the “check” light to come on. Replaced it and light has stayed off, just no sign of cooling. Switched it over to gas and burner fired right up and boiler section started grtting hot after a few mins.
44,027 PostsLatest Activity: Apr 19, 2019
