Bcamper's avatar
Bcamper
2000w Generator Running Microwave?
I just purchased a Yamaha ef2000is generator. It is a 2000W generator with s sustained 1600W rating; can go higher for small period of time. I hooked it up to our camper this afternoon and had it running for 30 minutes or so, I then ran the microwave in the camper and it worked fine. Tonight I plugged the camper into the generator and stared the generator and went into the camper and tried the microwave; it ran for about a minute (past the initial startup) then the generator went into overload (red light) and stopped the AC output. I did this several times; then decided to let the generator run 10 minutes; then try the microwave; and it ran fine for several minutes which was enough to pop a bag of popcorn.
The microwave in the camper is rated at 1300w. I had nothing else on (running) in the camper to cause a load on the generator..
The questions I have are:
1. Do these ef2000i or other generators build up a reserve so they need to run a few minutes before putting a heavy load on them?
2. Do others use 2000W generators and have issues running the microwave?
