May-25-2014 05:47 PM
May-26-2014 08:44 AM
May-25-2014 06:55 PM
jodeb720 wrote:Try the same test on the slot where the right trailer brake light fuse is located. (It is just below the left one).
I did check the fuse, put an ohm meter and the fuse is good. It's still not working. When I remove the fuse, and put the volt meter in the spot where the fuse belongs, I get no voltage to the fuse when the brake is applied, but when the left turn or hazard is enabled, it gets voltage.
May-25-2014 06:46 PM
May-25-2014 06:45 PM
rhochnadel wrote:X 2
Your truck has a separate fuse for truck and trailer turn signals, check out your fuse block for a blown fuse!
May-25-2014 06:08 PM
