- Reddog1Explorer IIPlease do not play the victim with me. Read your posts. Obviously you can't read those I deleted, but you should have before you posted them. This is not the first time you took a cheap shot at me. It was uncalled for. I have tried to get you to understand the negative aspects of many of your posts. You pushed hard enough on one thread that more than one member clearly stated the problem. It appears you read and ignored that thread, and now want to say you are a victim. I think you have a lot to offer the forum, but with a different approach.
Wayne
Moderator
Rules & Policies
Attacks on moderators will not be tolerated and may result in an immediate ban. - Kayteg1Explorer IIBut why are you making fight out of it?
You accused me of stirring the pot for guessing good explanation what happen.
That simply is not fair, especially that you seem to be very strong participant in this topic from the beginning.
I know that being moderator and active poster always make for unpleasant situations, but it is what it is. - Reddog1Explorer IIKayteg1, it is you that is getting personal, with your thread moderation comment. The only "fact" is I am the Moderator of the TC Forum. The "fact" is there is lots of things that happens here without my approval. I try to keep the the TC Forum within the guidelines of the Rules & Policies of RV.NET. It is not often I have to edit or delete posts, but on occasion a member will decide they are all knowing and the Forum is about them. More often than not, they are very knowledgeable but their ego gets so big it overshadows their knowledge with bully and arrogant post. Typically they insist on having the last word.
Wayne
Moderator - Kayteg1Explorer II
Reddog1 wrote:
Kayteg1 wrote:
Stirring the Pot, or simply a troll? Since you brought it up, I am more inclined to believe he was upset because moderation was needed.
I think OP got upset with thread moderation and deleted what he wrote on the beginning. ...
We are getting personal Wayne, but I simply stated the fact.
You can't deny that nothing happens here without your approval, can you? - Reddog1Explorer II
Freep, the OP edited his original post, for reasons unknown to me. I am guessing he was trying to be informative, and did not want to argue his point.todsme wrote:
Camper has been sold. The happi jac corner Jack's in 2005 ,4200 series had low torque powerheads and binded. Now they make the ,I believe the 4800 series.to rectify needing a stable- lift system, is to always keep the front of your camper lifted 3 inches higherwhen loading,unloading camper.That is until you are 2 feet from grounding camper. Especially with dually swing out brackets. This goes for any camper.keeps Jack's from binding and brackets from twisting.Remeber all the cantilver weight of sleeper.Also if you keep one rear jack off the ground ,you will reduce stress and binding of front Jack's.Try it ,the sleeper weight creates deflection thus really requiring only three Jack's to lower or raise camper.That is until leveled and set for use. - Kayteg1Explorer III think OP got upset with thread moderation and deleted what he wrote on the beginning.
The pictures that you can find links for show that the camper front jacks failed and camper drop damaging pickup on its way. That short time after purchase sure sucks and I feel for the poster.
One of the jacks bend, the other rip-off from the camper frame.
One failure had to lead to other, but question is wchich one was first.
I am just rebuilding lower front of my camper due the rotten wood behind jack mounts.
My camper has aluminium frame, what holds it together, but aluminium is only small skeleton, where lot of framing is still based on wood.
I discover that my front lower wall has no aluminium and the main beam holding sides of the camper was 3/4" x 3.5" where shear plywood was symbolic only. All attached with staples only. That for camper that loaded comes to 6500 lb.
The beam under the sides sag 3/4" per my measurements.
So to each fellow camper owner - inspect your jacks mounts very carefully and whenever you can, lower front jacks to keep the camper square. - FreepExplorer
todsme wrote:
Looking at truck Jack's as upgraded.
How did this whole thread come from this single post? I have no idea what OP is talking about. - Reddog1Explorer III think it is worth noting, the kid's playground equipment (Stable Lift) serves a useful purpose on the TC and the circus banners do not.
- FreepExplorer
Reddog1 wrote:
An interesting post; "I also don't want to drive around with my truck looking like I drove through a kid's playground and the equipment is stuck under the truck." If you have the typical decals on your truck, ever stop to consider maybe people think your truck looks like you drove it through a circus and the banners stuck to the TC. My point is, each of us have our own ideas as to looks.
Wayne
I Agree. We really dislike the swooshes manufacturers insist on putting on truck campers. - todsmeExplorerCamper has been sold. The happi jac corner Jack's in 2005 ,4200 series had low torque powerheads and binded. Now they make the ,I believe the 4800 series.to rectify needing a stable- lift system, is to always keep the front of your camper lifted 3 inches higherwhen loading,unloading camper.That is until you are 2 feet from grounding camper. Especially with dually swing out brackets. This goes for any camper.keeps Jack's from binding and brackets from twisting.Remeber all the cantilver weight of sleeper.Also if you keep one rear jack off the ground ,you will reduce stress and binding of front Jack's.Try it ,the sleeper weight creates deflection thus really requiring only three Jack's to lower or raise camper.That is until leveled and set for use.
About Travel Trailer Group
44,026 PostsLatest Activity: Mar 01, 2025
