Frankly
Apr 22, 2017Explorer
2006 Expedition W/Tow Pkg But No Charge Wire
I hooked up my new trailer expecting it to charge the battery while I drove. However, after some exploratory surgery I found that it had no charge wire hooked up. It did have the brake controller wired for the brakes. I finally discovered that my vehicle tow package only had the 4 pin plug installed. It apparently also had a brake wire in the bundle, as well, although I am guessing it was not hooked up. The 7 pin plug was added by a jack leg who was either too lazy or not motivated to install the charge wire. I finally figured out that the factory charge wiring stopped just under the drivers door and so I had to run the charge wire back to the plug from there. I had to add a relay and a fuse in the fuse box inside the vehicle. Not sure if anyone has run into this. The hard part was figuring everything out. If I had not had the Ford Service Manuals, I doubt I would have?:thumb:
