โDec-13-2013 12:30 PM
โJan-05-2014 04:24 AM
alexleblanc wrote:
Great looking truck, I'm jealous of the cap too, I need to look into one of those!
I test drove a few 6.2's and found they had all kinds of power with the 3.73's, I think you'll be plenty happy with it.
โJan-05-2014 04:15 AM
โDec-31-2013 07:50 AM
MFL wrote:
Congrats on the new truck!! That is a nice color combo (not inc green), and with the low miles, it is just broke in. At least with the 2-wheel drive, you could switch the gears, if needed, but don't think you'll feel the need.
Happy hauling,
Jerry
โDec-31-2013 07:25 AM
โDec-31-2013 05:04 AM
โDec-17-2013 12:41 PM
โDec-15-2013 05:22 PM
SoCalDesertRider wrote:Gdetrailer wrote:Haha. No BS about it, kind sir. I know exactly what I'm talking about. Sorry but you picked the wrong guy to go toe to toe with here. Check the ratings on the 18" and 20" tires for yourself. 3195 lb load rating per tire is flat out puny these days on a single rear wheel 1-ton pickup.SoCalDesertRider wrote:I call B.S., you don't know what you are talking about.
The smallest stock tire size also has the lowest load weight capacity. This negatively affects the truck's ability to carry a heavy hitch weight. Better off having a higher rated tire (18" or 20"), with a lower ratio axle (4.30).
My 2013 F250 IS equipped with the smallest tire size FROM FACTORY in 17"
LT245 75R17 Load Range E
That tire is rated at 3195 lbs max cap at 80 PSI
That is 12,780 lbs max tire capacity for the truck.
Take away my trucks weight (5600 lbs)you have 7,180 lbs LEFT OVER for "cargo".
My truck has cargo weight tag of 3,400 lbs.
That gives me 3,780 lbs EXTRA TIRE CAPACITY that I can not "use".
I would highly doubt that even a F350 is going to exceed those tires either....
By the way, my F350SRW has 3750 lbs per tire load rating and I have used every pound of it on the rear axle on that truck (7500 lbs).
โDec-15-2013 06:44 AM
โDec-15-2013 06:43 AM
โDec-15-2013 06:39 AM
MFL wrote:I agree.
I am not going to be involved in a keyboard spat, but will give my opinion. I chose to use the standard size 245/17, with 3.73 gears, when I ordered mine. Mine is a 4x4, so height was important, due to garage door clearance, and to keep my FW level. I also know that there is a gearing difference between the standard 31" tire vrs. the optional 34" tall tires.
Mine is a 250, so I do not need the load carrying cap. of the larger tires and wheels.
If I did need a heavy duty 350, with the big tires and wheels, to carry a big load, I likely would have opted for the 6.7, rather than the 6.2. If I had the big tires and wheels on a 350 and wanted the gasser, I would get the 4.30 gears needed to help off set the tire diameter.
JMHO, Jerry
โDec-15-2013 06:35 AM
โDec-15-2013 05:00 AM
โDec-14-2013 06:34 PM
โDec-14-2013 05:47 PM
