Joe417
Mar 21, 2014Explorer
Jage,
I raised the height using 2 sheets of 3/4" building foam. My camper weight is about 3800# empty which is about 0.83# per sq. in. on a flat surface. The truck bed isn't flat so it will be more like 1.6#.
Your camper would be about half the weight so it should ride great on the foam. The foam also gives you a bit of insulation which could help in cold weather.
44,030 PostsLatest Activity: Jan 20, 2025
