2012 GMC Sierra 1500 Tire Pressure Question
Mountianeer
GMC recommends 35psi. Tire max is 45psi. What should I be running and why?
Right now this is my daily driver. Sometimes carrying loads of mulch, gravel, etc. Not towing YET (TT next spring).
Thanks.
RVgapyear.com
2012 GMC Sierra SLE 4wd Ext Cab Z71 5.3L/3.42 w/tow pkg and Prodigy P2
2015 Coachmen Apex 239RBS w/50th Anniversary Package
3 REPLIES 3
Old-Biscuit
Hummmmmmmmm....what does the door sticker state for unloaded and loaded?
That's what I'd recommend.
The MAX on tire sidewall is the MAX PSI for MAX LOAD on tire.....not normal usage.
When hauling mulch/gravel then air up rear tires so that they aren't overloaded (under inflation kills a tire FAST)
Otherwise run the recommended psi front/rear
Goldstalker
X2, max them out for towing.
2007 GMC Sierra 1500 Crew Cab Z71 4X4 3.73
2013 CrossRoads Sunset Trail Super Lite 250RB
2-2012 Yamaha VX Deluxe
2012 Toyota Highlander
Cybergrunt
Former GMC 1500 owner and current F-150 owner. I always run recommended for daily driving (because the engineers obviously recommend it). When towing, I air up to max pressure (less squishy of a ride, less side-side).
2021 Forest River Wildwood Heritage Glen 24RLHL: 810-825# TW, ~7500# GVW
2020 F-250 XLT Super Duty SRW: 7.3 V8 gasser, 3.55, 10spd
