toms2012jayflig's avatar
Mar 13, 2021
2012 jayflight 26rks switching and slide lights not working
HI everyone. i recently purchased a 2012 jayflight 26rks and once home found the slide lights not to be working. Either trough the inverter or on battery alone. all other 12v systems work. So i was wondering what the two switches are for in the slide/awning cabinet that arent labeled but have something to do with lighting. checked most 12v fuses in the box labeled slide lights...it was good. thanks for any help till i figure this unit out more.....
Tom
1 Reply
  • Most likely broken wires feeding the slide.
    Since slides must move in and out, so, there has to be some slack in the wiring to allow this movement. Often done with a "curly cord" like you would seen on old fashion telephone handsets..
    Might want to check on the underside of the slide for the wiring and then you will have to find the junction points to see where the breaks in the wiring may be.
    Worst case may be if they hide the wiring in the walls or floor of the slide..
