2012 Ram 3500 SRW Towing Specs
djgodden
I'm looking for the above specs... GVWR, GCWR, axle data... etc. Anyone know where these are? I found the 2500 info but can't seem to locate the 3500 info.
2012 Ram 2500 4x4 Lariat Longhorn 6.7 CTD HO, Edge Evo CTS, Extreme Tow/Haul brakes, aFePower Diff cover, LL 5000 bags, 285/70R17, Reese Q20 w/slider. 2005 Montana 2955RL w/400w solar, Renogy MPPT, 4 x 6v @ 12VDC (450AH), 3000w Inverter, King VQ4100.
8 REPLIES 8
Grit_dog
Navigator
Navigator
On paper, less than what you hoped for....
In real life, more than you think!
Is that a good answer??
jmtandem
So how do you weigh a truck that's just a picture in your imagination?
Apparently you don't. But what you can do on your lunch break is use a DoD computer to log onto RV.net but not any Ram trailer towing/hauling webpages. So, it IS just a picture in somebody's imagination.
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
mkirsch
Nomad II
Nomad II
djgodden
I was looking just for the numbers because I was at work (DoD computer) during lunch and they don't allow pdf to come through. Ya, dumb but it's the guvmnt.
Found it when I got home...
jmtandem
I see you found it. Great.
SouthpawHD
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwivuKb_6-PLAhWmtoMKHa10DIwQFggkMAI&url=https%3A%2F%2Fwww.ramtrucks.com%2Fen%2Ftowing_guide%2Fpdf%2FRAM.2500.3500.Towing.Specs.pdf&usg=AFQjCNEiochaE42F0y1Ie678O37bZXnbZA&bvm=bv.117868183,d.dmo
Googled it, found it in 3 seconds. It's a PDF, about 2/3 the way through it looks to have 3500 data.
Palomino SolAire 307QBDSK
2016 Chevrolet 2500, CC, 6.0L, 4.10
donn0128
Scaled weight subtracted from GVWR is your load carrying capacity. If you have the 11.5 inch AAM rear axle it will be 11,000 pounds. But tire ratings will dictate what you can actually load the rear end to.
