May-15-2013 09:26 AM
Jul-29-2016 09:46 AM
Jul-29-2016 07:56 AM
bcsslc wrote:
This may be a bit late but I was experiencing a similar situation in my 276bhl 2013. I spent one afternoon and opened up all the the vent and traced the ducting from the supply. I notice that there was some random spaces that were being used with no vents. Also when I opened the access from the ceiling there seemed to be lots of cross flow from the return air and the cool supply. So any way I went through and blocked off any unnecessary ductwork and installed foam at the end just past the last vent. Also spent about an hour using duct board and ul listed Tinfoil tape and seal off the return air and supply. It does seem like a lot of work but it truly was not bad and I really got to know the workings of my trailer. Anyway by in blocking and sealing my a/c works great. 90* out and I'm 75* ish (depending on kids in and out) in about an hour. I also carry an small 6"to 8" vornado fan that I help move the air around.
Jul-27-2016 11:00 PM
Jul-26-2016 01:53 PM
kelly94942 wrote:
Hi all - we were out this weekend in our new Kodiak (300 BHSL) and we used the AC. It was only about 80 degrees out, so not super hot, but it took FOREVER to get cool in the trailer. The bathroom cooled down quickly and got quite chilly, but the bedrooms and especially the main room were warm for quite a while. We had some young kids with us so the doors were open and closed a bit more than they normally would be (in and out, in and out, etc.) but it just felt like the AC couldn't keep up. We haven't had this issue on our previous RVs, they got cold fast and stayed cold! We are taking a long road trip this summer and I'm thinking if it had a hard time in Oregon in the spring it's really going to have a hard time in Georgia or Texas in August!
Any tips or suggestions? Should we upgrade our AC? Add a second unit? Add a portable unit?
Oct-20-2013 10:33 AM
Oct-15-2013 07:00 PM
Oct-15-2013 05:17 PM
NLPRacing wrote:CarterKraft wrote:NLPRacing wrote:CarterKraft wrote:NLPRacing wrote:
We have a Kodiak 300BHSL also, and we notice that it has a hard time cooling down and staying cool. Did you ever find anything that helped? We're thinking about adding a second AC.
Do you have the 15k a/c upgrade? I have a 292 TQB on order and I am worried one will not be enough in the heat.
It has an Advent brand 15K AC. It just can't keep up with the Texas heat. We plan on adding a second 15K AC before next summer.
I hate to hear that, I was really hoping one unit would do it. You might want to look at the vents and there construction as I hear there are many complaints with the execution of them. I have found some similar complaints with Voltage trailers and several 300BhSL owners on the dutchmanowners forum. I have seen the same issue on the Heartland forum regarding ducted units and there is a "tent in the vent" mod by a member there named TimK that has seemed to solve there problems.
Would you say the airflow from the vents is adequate?
The airflow is okay, but could be better. The problem is, a trailer this big needs two AC's. I should of known better before I bought it.
Sep-23-2013 01:37 PM
Sep-01-2013 07:23 PM
Aug-31-2013 05:31 PM
JJBIRISH wrote:
Measured out about 2 feet from the AC there should be a 16* to 20* temp drop between the incoming air and that outlet air… if you have that the AC is doing it’s part…
Aug-31-2013 05:26 PM
Aug-29-2013 04:48 PM
Aug-29-2013 04:22 PM
Aug-27-2013 02:29 PM
