Gaffer222's avatar
Gaffer222
2015 Outback Terrain leaking
Hurricane Arthur helped me find the first leak. Put in the awning in due to wind and if I did not I would not have found the leak. Put awning out and leak stops. I had removed the divider in the under the stove cabinet day one. If I had not the puddle would have been hidden. Looks like water is getting in the outside kitchen hinge which is on the bottom of the door and dripping inside under the inside stove. Not sure If I will attempt fix or bring it in under warrantee. I will do the hose test and see for sure.
  • Yes defiantly have it fixed under warranty. If you fix it, and it fails again, the dealer may not honor the warranty any further.
  • Since it is new I would go the warranty route. I had heard that sometimes if you fix something yourself it nullifies the warranty. And taking a chance on causing more damage. Just my opinion.
