tama2112's avatar
tama2112
2016 SRW GMC 3500 Denali HD vs. Ambition AB-38FB - Thoughts?
Hi Everyone,
I'm about to pull the trigger on an Ambition 38FB. Wondering if my truck is up to the challenge?
My tow vehicle: 2016 GMC 3500 Denali HD. Here are the specs:
CREW CAB, STANDARD BOX, SRW, 4WD
Axle Ratio: 3.73
Max Towing Capacity: 17,200 lbs
Now for the Ambition AB-38FB. It has the 9,000 lbs axles. The GVWR is 21,460. Dry weight is "around" 16,000. Pin weight is 3,710.
Do you think the truck is capable of safely pulling this trailer with my family of 4 riding along?
Thanks!
