2017 Ram 3500 6.7 Cummins Recall
Butch50
I don't know if anybody else here got this mail yet from Ram.
It is for a recall for a possible fire in the engine compartment because of a water pump problem. It may fail without any warning and could cause an engine fire
They have no cure for it at this time.
I don't know if this is for any other 2017 Ram Cummins models or not.
Recall: T51/NHTSA 17V-562
Butch
I try to always leave doubt to my ignorance rather than prove it
2021 Winnebago View
33 REPLIES 33
bighog01
Got my notice for my 2014 3500 yesterday
SidecarFlip
Grit dog wrote:
SidecarFlip wrote:
All water pumps fail eventually anyway. I guess looking for a coolant leak under the truck (in the front) is too much to ask of an owner. Kind of like checking tire pressures or checking the oil.....
Right??
But I have a tpms and low oil light.....why would I check anything.....
Knowing you, I would presume that to be sarcastic,
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
reppoc12
WTP-GC wrote:
I have a 2014 Ram 3500, so likely not affected by this.
But if I did receive the notice, I'd pin it on the bulletin board next to the other 5 or 6 recalls I've gotten and have yet to address
I have the same truck, except for the flat bed, and received a notice yesterday. I suspect yours is coming.
Larry-D
My 2015 is included.
Grit_dog
Navigator
Navigator
Right??
FishOnOne
Vette Racer wrote:
Yep, got my letter yesterday for my 2016 3500, it reads that there is not a fix at this time and will be notified when one becomes available. Guess we should just quit using them until they have a fix, NOT! Kind of a stupid letter to send out IMO.
Actually the letter has served the purpose. You have been legally notified of a potential problem.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
WTP-GC
Duramax + Grand Design 5er + B & W Companion
SBGTF
SidecarFlip
I'd say, simple answer is... look under the truck for deposits (coolant) on the ground before starting it....
When your water pump fails, the seal fails and the coolant drips out the weep hole.
Guess I'm the minority, I always look under mine, everytime prior to starting.
Vette_Racer
KE5NCP
2016 Ram CC Dually, 2011 HitchHiker 349 RSB DA, 2018 Wrangler unlimited Rubicon
cummins2014
Ron3rd wrote:
ScottG wrote:
I'm sure the 3500's will be next. There is no difference between their engines.
The 3500's are included. They just don't go back as far in model years for some reason.
Got mine for my 2014 Ram 3500 last week.
cummins2014
Huh ! All water pumps fail, wow !! have I been lucky after 55 years owning cars ,and trucks, not one water pump. Couple fuel pumps ๐Ÿ™‚
SidecarFlip
IdaD
My truck already puked its water pump but I do have the recall notice on my Ram app. Not sure if the water pump I have on the truck now is bad or not, it was just installed back in late July. Once the pumps are available I'll run it in and have it looked at.
2015 Cummins Ram 4wd CC/SB
Lar_s
Just got mine yesterday for 2015. I had the mechanic look at it 2 weeks ago during an oil change at the dealer and he said it wasn't the model being recalled. On the other hand a friend with the same truck in San Antonio already had the fire. Go figure.
Lar
2015 Dynamax Trilogy
36 RL
Ram 3500 Dually
Ron3rd
Equilizer Hitch
Honda EU2000
