2019 Ram 3500 - dash display configuration?
gkainz
Hey Ram drivers - I just moved up from my 2007 Dodge Ram 2500 5.9 CTD where I have an Edge CTS display to show Boost, EGT, ECT, IAT for towing, to a 2019 Ram 3500 6.7 CTD.
On the new dashboards, how do you have your dashboard display configured to show your most important settings/gauges?
Thanks!
Greg
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
17 REPLIES 17
Cummins12V98
Having issues posting a pic of my display.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Bionic_Man
I didn’t think your question was confusing. I do think you have a number of folks here that for some reason have decided to be difficult.
On my 2012 I would toggle between the tranny temp and the coolant temp.
On my 2023, I keep it on the display below. I’m still getting used to the truck and the temps. The highest coolant I’ve seen is 217*, then the fan kicked on. At the same time, the transmission went to around 200, but so far it usually hangs out around 165.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
fj12ryder
I have to stand by my original answer: I simply don't have the same things up all the time. Nothing ever seems to change so I pretty much just put it in gear and go.
Howard and Peggy
"Don't Panic"
gkainz
Cummins12V98 wrote:
""On the new dashboards, how do YOU have your dashboard display configured to show your most important settings/gauges?""
Your question is deceiving as you show a pic of an aftermarket display. Taken literally the question is about the "DASHBOARD" meaning on the truck IMHO but you show something different.
Ok, that's an interesting twist I didn't think of! I didn't intend to deceive. The thought process was "This is what I had (the Edge gauge) and what parameters I used to watch. Now I have a new RAM display and it's a blank slate."
Original post basically said "Here's what I had - how do you have your dashboard set up?" ... I guess I don't see the confusion.
picture of the Edge display was here ...
Thanks!
Greg
Cummins12V98
rhagfo
gkainz wrote:
I can't believe how this normally helpful forum was so off the mark on this topic?
My original question was "On the new dashboards, how do YOU have your dashboard display configured to show your most important settings/gauges?"
I didn't ask how to configure, how to operate, how to navigate the screen setup ... I simply asked for some examples of YOUR favorite setup!
In the aviation world, setting up a NAV GPS, there's day long arguments about NORTH UP vs TRACK UP, but I don't think I've seen one of those discussions immediately dive to the bottom of the pool with "Hey, if you can't figure out how to set your GPS to Track Up, I'm not going to show you my setup."
Well what I display may be different than what is important to you. I have boost and speed, then a couple clicks away temp, trans temp, oil temp, and oil pressure. Another click and I have all six tire pressures.
gkainz
fj12ryder
Grit dog wrote:
^Apparently that’s what is perplexing the OP.
However after having an “old school” diesel without a factory DIC and presumably understanding the numbers and what they mean on the Edge on the old truck, it’s hard to make the connection as to why this is a question for the OP.
Now if only OEs had an EGT readout on newer diesels that would be nice.
Ah another helpful post. Refer to your own previous post.
Howard and Peggy
"Don't Panic"
fj12ryder
Grit dog wrote:
As silly as the OPs question is, both of you ^ need to go back to reading comprehension school….
You really should read up on how forums work. People ask for opinions, and opinions is what they get. Rarely are they explicitly what they requested. And I suppose your post was in response to his question? So maybe you're right.
Howard and Peggy
"Don't Panic"
Grit_dog
Nomad III
Nomad III
gkainz wrote:
Why? Because I'm also a pilot, and instrument scans is just part of normal operation! 🙂
@rhagfo - agreed! There's tons of info to be displayed - I was looking for tips on what people find helpful to display and common setups.
Then I would hope you can navigate the controls of a pickup truck. Just a really odd question is all.
Cummins12V98
rhagfo wrote:
Depending on trim level, there is tons of information available via the DIC (Driver Information Center) AKA Instrument Panel for old timers. On our Laramie I can display most everything.
EB braking HP and boost but no pyro.
gkainz
Grit_dog
Nomad III
Nomad III
rhagfo
