27 vs 31?
6pac
We are about to purchase a new battery for the TC an are going to upgrade to a group 31 AGM . Does anyone have any knowledge about the battery's that SAMs club sells? Any information both pros or con would be helpful !
Happy traveling
Chevy 2006 2500HD 4 x 4 Duramax / Allison srw cc sb Fh air bags
Lance 2005 model 881 Max
Doriece & Ernest ( 6pac )
15 REPLIES 15
full_mosey
bcbigfoot wrote:
I bought 2 of the Sams club 31 agm's last spring on my way through Jacksonville Florida they had Duracell labels on them but they are re-badged Deka Intimidators. They seem good, best bang for the buck but only time will tell.
I have an 8a24m Bass-Pro labelled Deka that is 5+ yrs old and going strong. We are dry camping in Quartzsite now. Deka is a good brand.
HTH;
John
full_mosey
Happy traveling
It depends on where your Sams Club is located. Eastern states get the Deka and all others get Johnson Controls.
Both are priced at $180 for grp 31. Depending on where I am at the time my current AGMs fail, I WILL get whichever one they have.
HTH;
John
eagle777
I personally will not run AGMs, I put 3 in my bass boat and 2 months later they were all dead, lucky for me BPS took them back under warranty. 31 is better than a 27 due to a larger reserve capacity so if you can fit them that's the size to use. make sure your invertor and or external charger are designed to charge AGM batteries or at least that selection. I personally wont change from a maintenance free marine battery.
jack
Manteca, ca
Ol__Gold
Based on this link, http://www.dekabatteries.com/assets/base/0194.pdf the group 31 AGM would have more amp hours than the group 27. Looks like a good move to me.
2001 F350 7.3 4X4 with some aftermarket stuff.
2013 Arctic Fox 990 with some nice updates.
1993 Duckworth jet sled AKA "TheDandyDuck" with some fish killing features.
1997 Seadoo GTX, 1996 Kawasaki 1100ZXI both with some faster goodies added.
bcbigfoot
2002 Dodge 3500 2wd dually, cummins, 4.10 gears, 10500gvwr, Rancho 9000's shocks
2005 Bigfoot 259.6E, 80watt solar, eu2000 Honda gen., 2x group 31 AGM bats., 7100 btu aircond, electric rear step.
time2roll
I see several on the website. Try to get the amp/hr specs.
At least make sure it is deep cycle rated as some are starting batteries.
Explorer1016
If you buy AGM's, you can lay them on their side also. In my Maverick when I removed the battery box I had enough room for 2 group 27's or 2 31's by laying the first one on its side then the 2nd one on top of it. they need to be secured well and I also placed a spacer between them and covered the battery posts. Good luck
2008 Host 300 Super 'C'
2008 Ford F-550 Chassis
Diesel
4x4
Lariat crew cab
20' enclosed car hauler/garage
'87 Jeep rock crawler
Turbo'd
ISBRAM
Boatycall wrote:
Can you fit in golf cart batteries? I have 6. Most everyone here will agree that's your best bang for the buck.
๐Ÿ˜‰
I run a pair of golf cart GC2's, I think it works much better than the two group 27's I had in my last camper.
1999 Dodge Ram 2500 QC LB Cummins
2018 Airstream Flying Cloud 28RB
If you see me camped someplace stop and say hi, I've always got an extra ice cold beer.
jimh406
Double check the measurements. I was short a bit to upsize even though it looked bigger. ๐Ÿ˜ž
narcodog
Well, look at that they do sell them but not available in every state. hat's a good price for and AGM,. I'd buy it.
6pac
Our Lance 881 doesn't have space for another battery . So our solution was to go from a 27 to a 31 . SAMs club has a 31 which has an AGM code on it an the price $179.95
Happy Traveling
Boatycall
'15 F450, 30k Superhitch, 48" Supertruss, 19.5's, Torklift Fast Guns
'12 Eagle Cap 1160, 800watts solar, Tristar MPPT, Magnum Hybrid 3k Inverter
'15 Wells Cargo 24' Race Trailer, 600 watts Solar, TriStar MPPT, Xantrex 2kw inverter
'17 Can Am X3 XDS Turbo
time2roll
n7bsn
Always the most amp-hours you can fit
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
