โApr-21-2018 05:58 AM
โMay-02-2018 08:09 AM
โMay-02-2018 06:55 AM
Huntindog wrote:
You keep saying it is only about the money...
Money is important, of course.
But if that were SAEs only motive, then why has the ford which is NOT certified, been spanked by GM over the years with a motor that IS certified with less power than the ford?
โMay-02-2018 06:37 AM
โMay-02-2018 06:21 AM
BigToe wrote:
Does Cummins identify, on any literature, website, or federally mandated document, that the 6.7L destined for pickups is certified per J1995, similar to how Cummins identified in the brochures of the two different M11s above as being certified per J1349?
BigToe wrote:
Is it possible that Cummins does use J1349,
BigToe wrote:
Can we at least agree that SAE J1995 is commonly referred to as the test for gross horsepower without engine driven accessories, exhaust systems, or emissions control devices? And can we also agree that SAE J1349 is commonly referred to as the test for net horsepower, still measured at the flywheel, but inclusive of the induction, exhaust, and after treatment systems as the engine would be expected to be configured in use?
โMay-02-2018 05:19 AM
BigToe wrote:
โMay-02-2018 04:19 AM
ShinerBock wrote:
"Cummins uses J1995 just like all engine manufactures that only make an engine and cannot control the intake and exhaust system of the vehicle the engine will be put in."
ShinerBock wrote:
"Even vehicle manufacturers test their engines the same way, but have to go by J1349 since they make the entire vehicle and not just the engine.
ShinerBock wrote:
"The only reason why SAE came up with the new J2723 requiring a witness was so that they can get money from the manufacturers which in turn makes our vehicles a little more expensive
โMay-02-2018 02:17 AM
Grit dog wrote:
Sweet! I knew this one would make 20 pages! Good job boys.
โMay-02-2018 02:02 AM
ShinerBock wrote:Huntindog wrote:
That is all is a whole lot.
Without the "witness" A manufacturer can bend some rules.... Oh my, that would never happen.
As Ford said. "The customer will get what WE rate"
Then of course they go on to get spanked repeatadly'
You can believe whatever you want.
If it walks like a duck, and talks like a duck.... It's a duck
I think you have mistaken me for a fanboy that cares about getting "spanked repeatedly" as if I care what stock power numbers are. As I have stated here, I bought my Cummins for its reliability knowing that I can tune it afterwards to the power levels I want which as it sits right now my 2014 is about 513 hp at the wheels on level 4.
I am just stating what I now how it works when I worked for Cummins. In order for an engine make to say are J1349 or J1995 they have to follow the guidelines of those certifications or it is false advertising. Anyone on the street can easily do a stock dyno pull and adjust for parasitic loss to tell if the power ratings are true are not.
The only reason why SAE came up with the new J2723 requiring a witness was so that they can get money from the manufacturers which in turn makes our vehicles a little more expensive. Manufacturers do the exact same thing to oil producers requiring to pay for the testing to meet their oil tandards. This does not mean that most oils won't meet that standard, it just means that only companies that fork over the cash to have it tested will be able to advertise it and say they do.
โMay-01-2018 07:34 PM
BigToe wrote:
I'm not buying the notion that Cummins only certifies engines, irrespective of application.
This thread began with a towing contest between some type of Ford (irrelevant) pitted against a recent model (2017? 2018?) Ram 3500. So to be safe let's look at a 2017 Model Year Ram 3500 with a Cummins ISB 6.7L diesel engine.
Remembering that Cummins only builds engines, not vehicles, we already know that Cummins put the ISB 6.7L engine into many other vehicles in model year 2017 besides the Ram 3500. For example, there is the Ram 2500, 4500, and 5500. There is also the Freightliner M2-106 and 108SD; the International Durastar, Workstar, and new HV series; the Autocar ACMD XPert (small refuse truck), ACX XPeditor (big refuse truck) and ACTT XSpotter (yard goat); the BlueBird Vision and All American (school buses); the dozens of motorhome manufacturers who outfit their class A coaches with the ISB 6.7L; the dozens of stationary power applications, off road equipment, airport shuttle busses, municipal busses... you get the idea.
BigToe wrote:
In fact, you established the idea, in this thread, that Cummins builds and certifies the engine without respect to the vehicle, "because they cannot control the intake and exhaust system that the engine will be put in."
BigToe wrote:
The notion that Cummins is certifying engines for Ram pickups as engines only, without regard to the regulated emission system components of the vehicle, is not supported by the 34 page application that Cummins submitted to the EPA back in 2015 to get their engine in the RAM 3500 certified for model year 2017, nor the hundreds of applications that Cummins submits every year, for every Engine Family number, of every Engine they make, whether for destined for fire apparatus, compressor duty, or racing Fords up mountains with trailer in tow.
โMay-01-2018 07:07 PM
โMay-01-2018 06:47 PM
No it is NOT false.
J1995 is a specified procedure for testing. It is actually an old procedure. It has been replaced by most with J1349. This is a more stringent procedure, BUT their were loopholes that too many were using to get misleading (higher) numbers. So it was updated in 2005. Realizing that some manufacturers could still find ways to manipulate the numbers, SAE came out with a new process at that time. J2723. It can go hand in hand with J1349.
What it specifies is that SAE must be present and oversee the testing to keep it legit. Only those that do this voluntary extra step can advertise their SAE numbers as "certified".
Check out what I posted earlier in this thread:
SAE certified power ratings
Hmmm, who to believe here. A biased fanboy who has never worked for an engine manufacturer and only wants to make hi favorite brand look good or someone who is unbiased here that has worked many years for an engine manufacturer and only want to give people the facts.
Or we can just believe the very people that set the certification standards.
Engine Power Test Code - Spark Ignition and Compression Ignition - Gross Power and Torque Rating J19...
"This SAE Standard has been adopted to provide a basis for dynamometer determination of gross engine power and torque under reference conditions. It is intended for use primarily by engine manufacturers who supply engines for installation by others in applications where the engine manufacturer may not control the induction and exhaust system design or the speed at which the engine is run"
What do they say about the J2723 that GM uses you ask?
Engine Power Test Code - Engine Power and Torque Certification J2723_201509
"This document specifies the procedure to be used for a manufacturer to certify the net power and torque rating of a production engine according to SAE J1349 (Rev. 8/04) or the gross engine power of a production engine according to SAE J1995.
Manufacturers who advertise their engine power and torque ratings as Certified to SAE J1349 or SAE J1995 shall follow this procedure. Certification of engine power and torque to SAE J1349 or SAE J1995 is voluntary, however, this power certification process is mandatory for those advertising power ratings as โCertified to SAE J1349โ or โCertified to SAE J1995.โ"
All three are certified standards per SAE with the J2327 being the newest with the main difference being that it requires one of these SAE-Approved Witnesses to witness the dyno testing so that SAE can get more money from the manufacturers to use certification logo. That does not mean that they are not certifications. It only means that in order to advertise the "Certified to J----", you have to pay for the witness. That is all.
โMay-01-2018 06:08 PM
ShinerBock wrote:
Cummins uses J1995 just like all engine manufactures that only make an engine and cannot control the intake and exhaust system of the vehicle the engine will be put in. This does not mean that Cummins(or any other engine manufacturer) cannot simulate the intake and exhaust system that these engines are going in, but they still can only do a J1995 certification since they only manufacture the engine, not the vehicle.
โMay-01-2018 04:59 PM
Huntindog wrote:
No it is NOT false.
โMay-01-2018 03:13 PM
ShinerBock wrote:No it is NOT false.Huntindog wrote:
And only the GM numbers are SAE certified.
What does that mean?
It means they are real.
Unlike the Ford moving from 440 to 450 in 2018. That was in direct response to GMs upgrade in 2017... I doubt anything really changed, other than the testing method, which was NOT certified.
This is false. All are SAE certified, but use different SAE certification processes. Cummins uses J1995 just like all engine manufactures that only make an engine and cannot control the intake and exhaust system of the vehicle the engine will be put in. This does not mean that Cummins(or any other engine manufacturer) cannot simulate the intake and exhaust system that these engines are going in, but they still can only do a J1995 certification since they only manufacture the engine, not the vehicle.
โMay-01-2018 01:01 PM
