buc1980
Jul 25, 2016Explorer
3:55 or 4:10
I wander what better to have on the truck rear axle 3:55 or 4:10 to pull a 15000 lb FW.What the mile difference driving solo?
NJRVer wrote:Chuck_thehammer wrote:
I do wish Eaton made a 2 speed rear end for pickup trucks..
I used to drive a White with a 5 speed transmission and a 2 speed rear end.
carrying 25,000 pounds of LEAD...almost daily
Wow, 25,000 pounds of LEAD?
Tougher than carrying 25,000 pounds of say, bird seed? :)
Bedlam wrote:
I'm happy with 4.30's, but do not drive over 65 mph. Many people have to lock out top gear when towing with lower ratios - My truck is used exclusively for RV duty, so I am happy being able to make most of the drive in 6th gear and the worst hills in 4th.
4x4ord wrote:
Towing even a very heavy holiday trailer down the highway at 65 mph only requires about 120 horsepower. What is the purpose of having your engine revving 2000 rpm in 6th gear where it is capable of delivering close to 300 hp to the rear wheels, Having a 3.73 gear ratio iinstead of a 4.30 would bring that rpm down to about 1735 which is still plenty high.....At 1735 the new Powerstroke is capable of delivering about 240 hp to the rear wheels. When I need more power than that I am happy to see the truck drop a gear or two where it can more directly and efficiently transfer the higher power to the rear wheels.
ROBERTSUNRUS wrote:You only operate the rear axle in high when in 2wd. Lockout switch keeps from accidentally engaging 4wd when the rear is in high.Chuck_thehammer wrote::) Hi, and how is this going to work with a 4 X 4? Not!
