Sep-11-2018 04:15 PM
Sep-12-2018 05:59 PM
Sep-12-2018 04:12 PM
Sep-12-2018 03:59 PM
richclover wrote:Huntindog wrote:
Not really totally true. Although a turbo MAY not keep all of it;s ability to increase power at high altitude, it will ALWAYS do better than a naturally aspirated motor. There are some variables in turbo systems on motors.... A variable vane turbo is one. The other is sizing. Many turbos control excess pressure by means of a wastegate that bleeds off excess pressure.... at altitude where there is less pressure, it will bleed off less if at all.boggerr wrote:
Where is everyone getting the info that a turbo is the answer? A turbo diesel at higher elevations is going to lose turbo efficiency. Less air, less combustion temps = laggy turbo,
RPM’s is the answer. Run higher RPM’s on hills and watch your gauges.
I respectfully disagree. At my house elevation, 7000’ MSL, normally aspirated engines, lawn mowers to piston engine airplanes develop no more than 75% rated horsepower. That’s why I flew a turbo-powered airplane rated for 31” manifold pressure to 20,000’ and tow with a Ram Cummins Turbo Diesel 😉
Huntingdog has it right, IMHO.
Sep-12-2018 03:44 PM
Sep-12-2018 03:37 PM
Sep-12-2018 03:07 PM
Sep-12-2018 02:40 PM
Sep-12-2018 09:53 AM
Sep-12-2018 09:52 AM
PaulandAnn wrote:
{snip}
Thanks again, I'll try and chill at higher RPMs.
ps
A word about tow mode: Once I was cruising along in Drive at 60mph, on a long straight gentle rise. I looked down and the trans temp was nearly pegged. I down shifted manually and the temp dropped right down. So in tow mode by itself, evidently, I was cooking the torque converter.
Sep-12-2018 09:38 AM
1320Fastback wrote:
Completely normal for a unboosted gas engine at altitude. Just downshift to keep rpms up, watch your temps and let the big guys get the tickets and clear the way.
Sep-12-2018 08:51 AM
Sep-12-2018 08:46 AM
Sep-12-2018 04:54 AM
Sep-12-2018 04:01 AM
Sep-12-2018 12:57 AM
