Aug-12-2017 11:59 AM
Sep-09-2017 05:27 PM
Powerdude wrote:
You should be a able to get a long-bed extended cab gas truck new, for the low $40k-ish.
Easily doable.
Sep-09-2017 02:35 PM
Oldtart wrote:burningman wrote:
If camper carrying is the truck's main purpose, why would you even look at singles? That makes no sense at all.
I guess because I'm still learning.
But I get it
Sep-09-2017 02:14 PM
Sep-09-2017 10:55 AM
Sep-09-2017 09:44 AM
Sep-08-2017 10:10 AM
Sep-08-2017 09:51 AM
Oldtart wrote:woodhog wrote:Oldtart wrote:
Follow Up
Although not a done deal it's looking promising.
I originally was seeing myself becoming a full timer but not yet anyway.
Hence the package I'm close to closing is a 2010 AF 811 on a 2004 Ram 2500 HD gas hemi. 59 K miles on it
I know this is a heavy camper.
Seller says he's put a lot of suspension work in.
1 ton dually spring pack with overloads on as well as having two of the original leaves reshapped and inserted.
Goodyear air bags. Rancho 9000 adjustable ride shocks.
Rear anti sway bar
HD steering stabilizer
New front U-joints
New ball joint ends
New discs brakes
He has changed the truck into a one ton and added all the right things
for a 2004 Ram..Good luck
36K
Should know tonight
Again thanks for all the advice and welcome any opinions pro or con
So I passsed on this deal even though I really liked the camper.
It was just too squirley for me when I drove it.
I have no experience in driving a truck with a camper and maybe I would have gotten use to it but it felt light in the front to me and would get a good sway going on a pretty good straight hiway if you weren't being real careful.
My gut told me the cg was too far back and in spite of all the seller has done to improve handling it wasn't a good match. I just think it was too much camper for that truck.
Nice guy and he took a lot of time with me but I need to see what a different set up feels like.
Sep-08-2017 07:42 AM
Follow Up
Rear anti sway bar
New front U-joints
New ball joint ends
New discs brakes
36K
Should know tonight
Sep-07-2017 05:29 PM
Oldtart wrote:
Follow Up
Rear anti sway bar
New front U-joints
New ball joint ends
New discs brakes
36K
Should know tonight
Sep-07-2017 04:22 PM
Sep-07-2017 02:03 PM
Sep-07-2017 01:52 PM
Sep-07-2017 01:41 PM
adamis wrote:
Something worth considering that I don't believe has been discussed is that IF you are going used, don't overlook the cost of SMOG repair bills if your used truck ends up without a warranty. I'm not an expert and others will have better suggestions but when I went shopping for my truck, I initially started looking at used trucks ranging from 2009 to 2014. What I found was that most of the trucks in that range (and were in my budget) had between 120k to 200k+ in miles. The mileage didn't bother me at all but it seemed that the newer engines with the more complicated smog requirements could be costly to repair / replace (especially the catalytic converters). The thing about Smog repair is that even if the truck is running just fine, if the check engine light is running, the nanny state won't let you register till it's fixed.
I ended up going with a 7.3 specifically because it was pre-smog. I don't have all of the bells, whistles and power the newer trucks have but I'm not worried about future smog repairs either. (I believe in 30 years the 7.3s will be sought after similar to how the 60s and early 70s muscle cars because of the lack of smog equipment). I ended up going with a 7.3 specifically because it was pre-smog. I don't have all of the bells, whistles and power the newer trucks have but I'm not worried about future smog repairs either. (I believe in 30 years the 7.3s will be sought after similar to how the 60s and early 70s muscle cars because of the lack of smog equipment).
Back to the camper section... If you are full timing and plan to put a LOT of miles on the road, don't underestimate the benefit of simplicity and light weight. Trucks today are built to handle the heavy loads pretty well but the stress put on your truck from a 3000lb camper versus a 5000lb camper will eventually show up. Also, though slides are nice and give lots of extra space, they also introduce failure points and areas for water penetration to occur. Again, this comes down to the number of miles your putting in on the road. A couple of hundred miles a year, no big deal, but full timing consider the use of those mechanical components and the exposure to the elements the seals will have to endure.
These considerations led me to conclude that I wanted a fiberglass camper because I anticipated being on the road a lot and though I really liked the space a slide(s) provided, I was concerned about how long it would last with the mileage I intended to travel.
Sep-07-2017 12:30 PM
jimh425 wrote:
You didn't mention the tires/wheels. That would be my concern.
