โAug-30-2017 04:16 PM
โAug-31-2017 08:12 AM
F450EC1165 wrote:rjxj wrote:
You cant compare a 12 v gp dual purpose battery to a gc2. As covered in the last go around compare a Trojan SCS225 to two T105
How about two of the Trojan T-1275 Plus at 150 AH each?
โAug-31-2017 07:49 AM
Freep wrote:Post the converter model number for best suggestions.
I don't how the battery is charged now when the gen is running or when I'm plugged in. I do remember seeing some device in the basement wired between the gen and something. I'll have to check that out.
โAug-31-2017 07:37 AM
โAug-31-2017 07:33 AM
โAug-31-2017 07:32 AM
Oldfordman wrote:
Biggest advantage to a pair of 6v batteries for a 12V system vs single 12V is the plate size in the 6V. It will stand up to more charge/discharge cycles as well as supply high currents with less plate damage.
โAug-31-2017 07:26 AM
โAug-31-2017 07:14 AM
โAug-31-2017 07:10 AM
โAug-31-2017 06:07 AM
GordonThree wrote:cewillis wrote:
I'd rather have (and do have) multiple 12v. If one is no good, you're still in business. And with the specs you mentioned, it's 220AH at 12v either way.
X2 for 12v
โAug-31-2017 04:43 AM
work2much wrote:jimh425 wrote:
People are in favor of 6V for less cost for same capacity/durability. Disadvantage is that you need both batteries to power your system.
I have no reason to switch to 6V batteries currently since either system works for my purposes.
It's true but a decent battery that is maintained with proper monitoring and charging is a pretty reliable source of power whether it's a pair of 6v or a single 12v. These are essentially the same aside being connected by cables vs encased in a piece of plastic.
Could one 6 volt battery fail completely and render a 12 volt system unusable? yes, but I don't think it is any more likely than a 12 volt battery losing individual cells.
โAug-30-2017 11:58 PM
โAug-30-2017 11:33 PM
โAug-30-2017 10:51 PM
โAug-30-2017 10:13 PM
โAug-30-2017 09:37 PM
Freep wrote:pianotuna wrote:
It depends.
My own preference is 12 volt. I do that because I run a medium size 3000 watt inverter.
This is interesting. How does the inverter figure into this? At some point I'd like to add an inverter too. The hope is to one day be able to run the MW for a few minutes without running the gen.
