sarhvac1
Mar 04, 2017Explorer
7.3 repair bill ouch
had my 7.3 to the dealer for Waste Gate actuator and heater fan stuck on defrost,,, $963.00 later runs like a champ. still cheaper than a new truck payment ok rant over!!
marcsbigfoot20b27 wrote:BigToe wrote:2oldman wrote:
I had all kinds of expensive problems with my 2003F450 7.3. Oil leaks from the high pressure pump was one... by 120k it was getting very expensive.
The original post, and this post above, both illustrate how the longevity/value ratio of any given tow vehicle cannot be judged on reports of how much people report spending on repairs.
Take leaks from the high pressure oil pump as an example. The resolution is a $15.00 bag of Orings. Yet some people get charged $1,500.00 for the repair, and are happy to pay it, because a high pressure oil leak looks so catastrophic. Streetwise service departments, as well as independents, know when and how to sooth a customer, and at the same time strike without their greed being noticed.
Should a tow vehicle platform be indicted as not a good long term value because a few people might pay too much for repairs? Of course not. Can everyone do their own repairs? Of course not. But while some folks find it useful to compare service bills, including charges for labor, I find it more instructive to compare what specifically went wrong, and what parts were required to fix it.
Knowing what exactly failed, and what parts actually needed to be replaced (as opposed to the parts that were just thrown at it, or unnecessarily replaced to generate more revenue) helps remove the opportunistic service departments / mechanics from the equation in determining the value proposition of a tow vehicle platform, and shifts the focus solely on the longevity and failure frequency of the product itself.
Here is what that stupid little oring looks like when it goes.......
lightning driver wrote:RAS43 wrote:
Mild tunes were not an issue with the 7.3's. The transmissions were weak but mine had been updated but still failed after coming down Wolf Creek Pass, one of our "hills" here. And I tow doubles so weight is around 20000lbs. Probably a bit harder on a vehicle.
Out of curiosity were you watching trans temps going up the pass? Heat is a transmissions enemy. Thinking you may have pushed it too hard.
I run 6% grades heading North out of Phoenix pulling my 20K toy hauler and keep an eye on trans temp and EGT's. Always try to keep Temps in a reasonable range. Which of course means 35 to 40 MPH up the grades.
Cummins12V98 wrote:
Like AMZ/OIL or not they are why we have synthetics in the auto industry.
FishOnOne wrote:Cummins12V98 wrote:
^^^^^^^ Fish WOW good thing I basically said what I said back then!!! I did NOT say "SLUDGE" as YOU misquoted me!! Thanks for proving your self completely incorrect!
So what is your point???
Point is.... It's ok for others to use Delo but when fish try's it.... well you get the point! :W
Okay I'll just say it... :B The point is we all know you like to market Scamz/oil.... There.... I said it! :B
