Perhaps I need to step in here to clarify some items:
First, read my write up on Tire Standardizing Organizations:
Barry's Tire Tech - Tire Standardizing OrganizationsThen understand that the US Federal government ACCEPTS those standards, but doesn't REQUIRE a tire comply with those standards. It does require the tire to comply with certain marking and testing regulations, but a tire manufacturer is not obligated to follow those standards - although why anyone wouldn't is beyond me.
The Kumho Radial 857 is a tire line designed to ETRTO standards and for use on utility vehicles commonly used in Europe, but rare in the US. The VW EuroVan and the Ford Transit are probably the only vehicles that the US folks would be familiar with. These vehicles are smaller than what is commonly used in the US for the same purpose.
The line carries the "C" designation (for Commercial), which is printed AFTER the tire size. This an ETRTO designation.
Because of that, the US arm of Kumho obviously sees this line of tires as having only usage on trailers - as the vehicles this line fits on basically don't exist in the US - and only lists 3 sizes, all 14".
Some LT tires CAN be used on trailers, but some are just not suitable - BUT - ST's are specifically designated by the US tire standardizing organization, The Tire and Rim Association, as trailer tires. That's what the letters ST mean - Special Trailer. This designation is a US only designation. It does not appear in ETRTO, nor JATMA yearbooks.
But be very careful interpreting what is published by the tire manufacturers. The wording becomes very important. For example, if a tire manufacturer is asked if an LT tire can be used in place of an ST tire, the answer will be "no" - because an LT tire of the same size will have a lower published load carrying capacity. No tire manufacturer will want to be in the position to defend that in a court of law.
However, if you ask if an LT tire is suitable for use on a trailer, the answer might be "Yes" - as the question asker hasn't defined the loading and there are situations where an LT can be used on a trailer. Just be aware that the tire manufacturer might not agree that their LT tires SHOULD be used on trailers - and say "No".
