-8 cold start
brooks379
A few days ago it got down to - 8 degrees here in the mountains of NM when I went to start my Ford F-350 6.7 diesel I hit the glow plugs just until the light went out , about 5 seconds and the truck started like a summer day . I can remember back in the day trying to start diesel trucks and if it wasnโ€™t plugged in it was going to be tough to start. You had to run your glow plugs 4 or 5 times and if it did start it would smoke and buck for about 5 minutes before idling smooth. The other day the 6.7 started up, no smoke , no rattling. These new diesels start right up like a little gas motor these days. ๐Ÿ™‚
21 REPLIES 21
alexleblanc
When I compare my current truck and even my previous โ€˜13 6.7 to my first diesel, an โ€˜04 VW Golf TDI that I had bought new - that **** thing would smoke and sound like a bucket of rocks going through a blender in anything below 20 degrees. Had a few really cold mornings that I couldnโ€™t even get it started (-25 or so F). Those certainly were not the days!
TV - 2017 F350 CCSB SRW Platinum 6.7 + 5er - 2021 Grand Design Reflection 311 BHS + B&W Companion
On Order - 2022 F350 CCSB SRW Platinum 6.7
Cummins12V98
Simply run AMZ/OIL Signature Series 15-40 year round and not worry about seasonal oil changes. Good to -40 but hey the 5-40 is good to -43.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
shepstone
blofgren wrote:
One of the reasons the 7.3L and 6.0L weren't great cold starters was the oil fired injectors. I actually had to cycle the glow plugs on my 6.0L in the summer or else it would start very poorly if at all.
Now my current 6.7L Cummins is another story; I rarely use the grid heater and it fires up quickly and smoothly every time. :B
Thats not much to brag about. I lived in North Delta & Surrey BC for 8 years the coldest it ever got was -8 C one night. So I should think it would start up. I came to Ontario and -8C is a warm winter day, last winter the Super-Duty started no problem at -36 and it never gets plugged in.
2017 F350 Ruby Red Super Cab Dually 6.7 3.55 gears. B&W Companion 25K. BackRack. Gatorback mud guards. AUX65FCBRG aux tank. 2021 GD 380fl
2010 GMC Savanna 3500 extended 6.0
ACZL
Full synthetic is the only way to go. I'm a bit overkill, but I run a winter front to block the cold air from radiators. IMO, does 2 things. 1. Keeps the air from getting to rads. 2. Keeps whatever stuff (rock salt/stones etc) from getting into rads. Work is only 15-20 minutes away so I want to be able to get it up to full operating temps both ways or perhaps a tad higher. Without stones, rock salt etc from getting to rads helps keep possible holes from occurring, aid in not plugging the holes in rads, and lastly, perhaps help keep things from rusting out. During summer months, I run a full bug screen front to keep bugs out of rads. When I got rid of my '03 F250, the rads were clean as a whistle! And that had full bug screen and winter front inserts.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
ktmrfs
theoldwizard1 wrote:
I'll bet the OP is using synthetic or semi-synthetic oil ! I makes a big difference below 0F.
I remember almost 50 years ago, My Dad tried Mobil 1 (?) because he would visit our cabin in northern MI several times each winter. That engine spun over like it was a spring day ! It did make a few "odd" noises, but it kept running.
He gave up on the Mobil 1 because he could not stand the 3 to 5 times cost increase. He would just put a battery charger on over night or decide not to go when it was going to be below 0F !
back in the 1960's conoco had an oil call "polar start" I think it was a synthetic or partial synthetic, 10W-30ish that also at very low temps -30 or lower would definitely let the engine spin over quicker. At those temps once you got moving one realized that shock absorbers, didn't really absorb much of anything till they also had got enough up and down to get the oil warmer as well.
2011 Keystone Outback 295RE
Lynnmor
Edd505 wrote:
I had to laugh as when I bought my 6.7 I sat looking at the dash and the mechanic asked what the problem was. Wheres the wait to start??? He had to educate me, never an issue starting.
The "mechanic" should have pointed out that squiggly icon on your dash because it is the wait to start message.
While starting is quick on a 6.7, I still wait for the icon to go out because it does insure more complete combustion at startup. Using the remote start, the engine will start when the appropriate delay is complete.
theoldwizard1
ktmrfs
I started my 04.5 duramax at -40F no problem. no way to plug in the block heater, it had sat out for 10 days with highs near zero, lows in the -25 to -40 every night. turned the key waited for glow plug light to go out, turned ignition off, then on waited a second or so for glow plug light to go out, started right up. smoked a bit and rattled, but started no problem.
actually started far better than a 1960's vintage gas engine would at those temps!
Now warm up time, another story. the trip was downhill for about 15 miles, even with tow/haul on getting heat was a LONG process! Thank god for heated seats!
A far cry from 30-40 years ago when diesels were tough to start below zero.
Edd505
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
All_I_could_aff
Carburetor icing has always fascinated me.
1999 R-Vision Trail Light B17 hybrid
2006 Explorer Eddie Bauer
2002 Xterra rollinโ€™ on 33โ€™s
1993 Chevy Z24 Convertible
Lives in garage 71,000 miles
blofgren
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
time2roll
Yes my old gasser has started at -10(F) just fine a few times.
My old car with a carburetor would ice up and stall for the first 15 minutes in similar conditions.
Lynnmor
Two years ago, I was in Maine snowmobiling for a week. The club members on each side of me had 7.3 Fords and I had a 6.7. When it was time to leave the temperature was -6 degrees. One 7.3 fired up and complained greatly, the other wouldn't start perhaps because of weak batteries so he called road service. Both were plugged in all night. I hit the remote on mine and it was just like a summer day even though the 7.3 owners hogged all the available outlets for their block heaters.
Lessmore
-8 is nothing. New Years night it went down to -31 up here.
