99 Chevy Suburban 1500
ugh
A friend of my is asking a lot of questions about his truck. It is 99 Chevy Suburban 1500. He said that his gross combine weight is 14,800 pound. I was puzzled on how he got that. He basically added the max two weight (8,000) and GVWR (6,800). Is that the right way?
He is trying to figure out how much weight he can pull. NADA says 8,000 pounds, but I don't think it applies to him as his truck is not diesel, but 350V8.
2001 F250 5.4 3.73
2015 Wildwood X-Lite 262BHXL
7 REPLIES 7
APT
4 spd trans means 3 useable towing gears for high walled RVs.
2017 Subaru Outback 3.6R
blt2ski
Moderator
Moderator
APT wrote:
GCWR is closer to base curb weight + 150 pound driver + tow rating.
Anyway, 3-spd auto and the 17 year old 5.7L - 5000 pounds tops loaded weight if it is in well maintained condition.
Try 4 spd 4l60e trans, not a turbo 350/400 behind that motor!
Issue will probably be the 3.42 gear sets if that is what Jerome is hinting at. my 4.10 geared rig with a 4l80 has some spunk. Not as much as some combo's, but not bad......
marty
92 Navistar dump truck, 7.3L 7 sp, 4.33 gears with a Detroit no spin
2014 Chevy 1500 Dual cab 4x4
92 Red-e-haul 12K equipment trailer
APT
VAfan
I have a 99 Tahoe with the 5.7. It's a great running rig but there is no way I would try to tow anything over 4-5K.
2x - I owned a 99 Yukon 4x4 with the 350. I towed a 6500lb trailer and it was maxed out.
jerem0621
Here is a great resource to start with
1999 Towing Guide
Looks like the 8,000 lb tow rating is for the 6.5 turbo diesel. The 5.7 Maxes out at 6,500 lbs towing.
Good Luck.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
It’s Kind of Fun to do the Impossible
~Walt Disney~
Cummins12V98
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
blt2ski
Moderator
Moderator
IF he has 4.10's his gcwr is 13500 or around 8000 lbs of trailer if his burb weighs less than 5000 lbs with a driver full of fluids.
373 is 12500
3.42 is 11500
3.08 is 10500
With that said. He will run out of payload with his burb before he runs out of pulling power! I've pulled a 12K trailer with my 2000 c2500 with 4.10s and it was not what I would call an issue. I was going 45 up a 3% grae from a standstill at 18000+ pulling my equipment trailer with my MDT when a motor mount broke. Dad showed up in this truck. did not know he had it. Put the pintle hitch from Navistar into reciever of C2500, drove the trailer to a job site 10 miles away. My truck is 4700 empty mind you! yeah one of them stripper 3 factory option rigs. IE automatic, tow pkg and trim rings. Oh and cloth seats which is a N/C vs vinyl......
Marty
