9K Coleman AC and Yami 2k
Area13
We have been on about 6 trips in our new TC so far and for the first time this week got into a little heat that was uncomfortable for the Wife. We were just looking for an hour or so to cool down a bit during the heat of the day. I specifically got the 9k AC unit to run on our Yamaha 2k and knew it might be tough.
It ran the unit fine in my driveway (of course) for about 30 minutes, sea level, 80 degrees ice cold, no problem, batteries charging and a couple of lights on.
We tried to use it twice this week, 2 different spots, both about the same altitude WA Cascades about 2500โ€™. Edit-ECO WAS OFF.
1st attempt-92 degrees, part shade, fail. Even dxโ€™d the battery switch feeding everything, poor little genny.
2nd attempt- 88 degrees full sun, worked. Ran it for about an hour, much happier Wife, batteries charging, couple of lights, no trips.
Thinking maybe a Honda 2.2k might get it done better? It is the same size and will fit in my custom compartment just fine also. The Yami also struggles to run my fridge and chest freezer at home during power outages. I have a buddy that said Heโ€™d give me $650 for it, bought it new for $875 several years ago. Might be time to bite the bullet. Anyone have any experience with the new Honda 2.2k and a 9k AC in similar situations?
2020 Outdoors RV 21RD
2015 F-150 FX4 5.0 3.73
18 REPLIES 18
n0m4d
I know this topic is contentious but after a bunch of research I'll picked up a Ryobi 2300 (RYI2300BTA) generator this summer. Aside from the Honda with it's Hondaness and the Yamaha with it's Yamahaness, the Ryobi seems like the best inverter gen out there. It runs my 13.5 btu Dometic with eco off (and with the charger/converter on). I've been very happy with it and it has some nice features that others do not have.
Buzzcut1
Nomad II
Nomad II
Spin up the fan before switching it to the low ac setting.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
sbryan
No experience with the new 2.2 Honda but I have the same AC on my Northstar Igloo and the Honda 2.0 just handles it as long as it isn't in Eco mode. I'd love to have the 2.2 to have just a bit of extra oomph but the 2.0 will get the job done, even in 100 plus degree heat (think the Badlands at 103 indicated). Just a data point on the old Honda so the new one should have no issues. Surprised the Yamaha can't handle the same load with the same rating.
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
towpro
make sure you have the refrigerator running on propane, make sure the hot water heater is running on propane, not electric and as a last ditch effort you can throw the breaker for the battery charger. I would expect that gen to run the AC. I have a different 2K generator and never had a problem, but all my camping is at Sea Level at the beach ๐Ÿ™‚
EDIT: after reading more posts, I feel I do need to point out that my red 2000 runs my 8800 btu AC on my arctic Fox great, even on eco mode. and I have mine wired so thermostat turns on both AC AND fan the same time.
I can also leave the battery charger running at the same time but by the time of day I would be running my AC I have already gone through a full solar day of charging batteries so not much load on charger.
2022 Ford F150
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Sold Forest River Forester 2401R Mercedes Benz. when campsites went from $90 to $190 per night.
