Majja13
Jul 24, 2013Explorer
AC Question, Ac freezing up
Ok we were out in our trailer last weekened and if I let the AC run from more than an hour it would freeze up. The air flow would reduce drasticly. If I shut it off for about an hours I would get a steady stream of run off and it would work again. And ideas what would cause this? I was at an elevation of 8800 ft. I do not use the AC that much but last year it ran like a champ. Could it be just a little low on gas? if so do they take the same gas that cars and trucks take?
Thank You
Matt
Thank You
Matt
