Add Awning To Slide?
Arn
Apologies for the crossthread if you're also on the Jayco Owners forum. I have a 2015 Jay Flight 33RLDS & I'd like to add an awning to the door side slide. Has anyone ever done this? Is it even possible? Thanks.
Arn
1958 Me
1963 Her
2015 Jayco Jay Flight 33RLDS
2020 Silverado LTZ Crew, 5.3 Max Trailering Pkg.
22 REPLIES 22
Mike134
kellem wrote:
Another option is a telescoping latter and a swiss broom....I'm being serious.
We've had trailer's with slide toppers and those without and prefer those without.
After owning a trailer with slide toppers for duration " 10 years " I've come to the conclusion that sweeping off the top and treating the seals trumps fighting mildew and dry rot seals.
Our latest trailer has no toppers over the slides and we leave slides out year around.....much preferred. Ymmv
That's what I currently do. Have considered a slide topper but how do you keep a puddle of water from forming in rainstorms?
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
kellem
valhalla360 wrote:
ford truck guy wrote:
Not 100% sure about your Jayco, but from what I understand it needs to be done during the build..
I was told my a manufacturer a few years back that they NEED to "pack out" behind the slide for the awning rails to mount to for support....
That may have been a sales pitch..."you can't get it unless you buy the overpriced option from us."
Usually, they build the main box the same and just bolt on the extras.
Obviously, check to makes sure there is a stud you can attach too but it's unlikely they built it out differently.
Thought that at first, but it was the manufacturer rep.. she tossed in the 2nd awning when dealing with her but we had to decide before the build... so, no cost to us
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Mike134
Top of the wall has to have a 2x running the entire length just like your house wall otherwise there's nothing to attach the vertical studs to.
valhalla360
Nomad III
Nomad III
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
aftermath
I don't think so. Take a look online and you should be able to see many options. A friend of mind just did this and said it was pretty easy. I was looking into one just before I sold my trailer back in 2009.
2017 Toyota Tundra, Double Cab, 5.7L V8
2006 Airstream 25 FB SE
Equalizer Hitch
GrandpaKip
Donโ€™t see why not. A lot would depend on the skills of the installer.
My question would be what is the effect on the slide when the wind buffets the awning?
Is there room to add the awning over the slide so it is attached to the trailer?
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Me-Her-the kids
