imq707s's avatar
imq707s
Added trailer hitch, strong enough to pull ATV trailer?
I decided to make a trailer hitch for our 19ft Zinger trailer. We want to be able to hang a bike rack off the back, and maybe even pull a small ATV trailer (you can double tow in Missouri).
I made this out of 2x2 square tubing with 1/4" wall thickness....pretty heavy stuff. I welded up the whole structure first, and then slid it right in between the frame rails on the trailer....and welded it to the frame in several spots, and also welded it to the factory square tubing bumper in several spots.
Should I have any problem towing a light trailer with this setup? Thoughts?
