Adding roof AC to camper
noteven
I'm looking at adding something like a Mach 8 9000btu unit to my Snowbird/Snow River 8-1/2 ft 1 slide camper.
Will my little phart Honda 2000i generator run the 9000btu type unit?
If yes, to what altitude?
Thanks
11 REPLIES 11
lawrosa
Micro-Air wrote:
lawrosa wrote:
taughted soft start caps
We like it! ๐Ÿ™‚ New product tagline:
"EasyStart: The best self-taught, soft start in the world!"
Spelling error..
""""TOUTING""""
Mike L ... N.J.
2006 Silverado ext cab long bed. 3:42 rear. LM7 5.3 motor. 300 hp 350 ft lbs torgue @ 4000 rpms
2018 coachmen Catalina sbx 261bh
Micro-Air
Technical Support
Micro-Air, Inc.
trail-explorer
trail-explorer wrote:
what on earth is a taughted soft start cap?
hmmm.... "taughted" isn't even a word
Bob
trail-explorer
Bob
Buzzcut1
Nomad II
Nomad II
06Fargo wrote:
Good points thanks
Anyone running the 2000i at 4500 - 7000 ft?
me, running a Polar Cub 9000 at around 8000 feet along the west fork of the Carson river without missing a beat
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
noteven
Good points thanks
joeshmoe
As hedge said, consider getting a powersaver model. My Honda 2K does great with it. Unless height is a concern. I'm Not sure they make a PS in the 8" model.
2014 Northwood Wolf Creek 850
2005 Ford F350 SRW SuperCab/LongBed 6.0 Powerstroke
QuickTrick's Towing Tune
Torklift Tie Downs/Fastguns/Upper/Lower Stableloads
Rancho 9000's
hedge
I installed the Mach 8 on mine, it's nice in that it's only 8" off the roof, but it's loud. The Honda runs it but it works it pretty hard.
You can't go directly by the btu ratings, go by the amp ratings as I believe there is an 11k that actually has a lower amp draw.
2017 F350 Platinum DRW
2013 Adventurer 89RB
Itchey_Feet
We installed a 9000 to our Summerwind as an aftermarket install, our 2000i starts and runs ours with no problem.
My feet are fine as long as they are traveling.
ScottG
The Honda should have no problem starting and running that size of AC - even without mods although those would certainly not hurt.
lawrosa
Get a micro air easy start. This is a good product and way better then the taughted soft start caps out on the market..
https://www.youtube.com/watch?v=soP0uZFd0nQ
About 300 bucks with the case. If your handy you can just get the board for 150 bucks..
http://www.microair.net/main/products/product.php?id=20
Mike L ... N.J.
