There is NOT an adjustment tab on fins in back of fridge.
You make adjustments on the upper control panel.
(There is a 'thermistor' on far right fin inside food compartment for temp sensing. Repositioning it ONLY works on fridges with AUTO Temp Control ----- fridges w/o adjustments)
Fridge in slideout SHOULD have fan(s) installed in outside compartment to enhance air flow thru the absorber tubes (slanted heavy tubing) and across condenser fins (finned unit at top)
Remove upper vent and look down...should be able to see fan(s) centerline mid-position of fridge.
IF RV MFG. bothered to follow fridge mfg. installation instructions/recommendations.
Majority of 'cooling issues' are due to improper clearances (too much clearance), lack of baffles (to decrease clearances & direct air flow) and not installing fans when in a slideout to help 'draft'
Installation instructions are available on line.
