Camp woof wrote:
I get my Bigfoot 10.4 end of May ...
Anybody going with LiFePO4 batteries??
Dave
We made the switch a little over a year ago. LFP batteries have several big advantages:
1. They can be charged faster. With a quality solar charger you can charge at full voltage. LFP does not need absorption or float charging (tapered charging)
2. Much lighter and smaller. Our 600AH battery weighs 175 pounds and fits in the generator compartment. As a comparison, a usable 600AH of AGM would require 10 6v batteries and would weigh 650 pounds. Plus need a ton of space.
3. More life cycles. This helps with the cost comparison.
4. No need for a full charge. Unlike traditional batteries you can use LFP anywhere in there usable range. No need to top off regularly or equalization charging. This is very helpful when you are relying on solar and full charges don't happen for days or even weeks.
5. They can be discharged at high rates and have very little internal resistance. Our system can be discharged at 2C or 1200AH. Well past what our inverter can do.
There are some popular drop in replacements like Battleborn. They have a built in BMS so any charger will work although to take full advantage a programmable charger will peak efficiency.
These batteries are pricey though at close to $1,000 per 100AH. To reduce cost to something closer to AGM I did my own LFP build using 3.2v cells. That reduced cost to $550/100 AH.
We have used the system for a year including high draw items like the water heater, air conditioner, toaster oven. LFP makes quick work of these items. No more generator.
![](https://i.imgur.com/ZNblKVll.jpg)
![](https://i.imgur.com/vvrSShWl.jpg)
