Richandtd's avatar
Richandtd
air bags and torklift tiedowns
I will be getting some air lift air bags to help level out the truck. So when they are installed due you inflate the bags then put on the torklift tiedowns with thier 300 pounds of spring tention? Just trying to due things right.
  • get some Timbrens...much easier...Last set of airbags I had..I bent the bracket when I hit a pothole on a snowy road...
  • d3500ram wrote:
    I do not have air bags, but correct me if I am wrong... but isn't the relationship of camper to bed (via Torklifts) remain the same regardless of airbag position?
    ...that is, airbags do not affect what you are asking- it affects height of suspension.
    yep, airbags axel to frame. torklift frame to TC . one has no effect on the other.
  • I do not have air bags, but correct me if I am wrong... but isn't the relationship of camper to bed (via Torklifts) remain the same regardless of airbag position?
