n0arp
Jul 24, 2021Explorer
goducks10 wrote:n0arp wrote:
You get to choose between 12V and 120V when you order. Whichever you choose, you're stuck with. Our house bank is 48VDC and inverter always on, so we decided to go with 120V.
It's an easy DIY project, if you're handy.
We went with the conversion because we camp at high elevation, don't always level, know about the fire risks associated with (especially unlevel) absorption units, etc. And of course, we have enough solar/battery to comfortably opt for the consistency and other benefits of a compressor unit. That's something you have to account for, depending on how you camp.
I've since replaced the unit with a Haier 9.8 cu. ft. apartment fridge, which has the same exterior cabinet size but a lot more usable space inside, and uses roughly the same energy. With the conversion, you're stuck with the same usable space as the fridge you start with. A 7.5 cu. ft. Norcold vs 9.8 cu. ft fridge residential, and in our case, the space is important enough to justify the change.
According to the Haier safety instructions that fridge is not supposed to be installed in an enclosure.
http://pdf.lowes.com/useandcareguides/688057309156_use.pdf?_gl=1*1wc67qi*_gcl_aw*R0NMLjE2MjcxMzU4NzMuQ2owS0NRanc5TzZIQmhDckFSSXNBRHg1cUNRamRTUG1MTlZuYjExLXVDQjljZjQ0OHZ5djZoS2p5dm5GRGVWUWJ0alBRZzZCdzV4TWQyWWFBbjZ1RUFMd193Y0I.*_gcl_dc*R0NMLjE2MjcxMzU4NzMuQ2owS0NRanc5TzZIQmhDckFSSXNBRHg1cUNRamRTUG1MTlZuYjExLXVDQjljZjQ0OHZ5djZoS2p5dm5GRGVWUWJ0alBRZzZCdzV4TWQyWWFBbjZ1RUFMd193Y0I.
I've read so many instructions PDF's from 120V fridges and most all small (10 cu.ft and under) 120V home fridges don't make the cut for RV install.
It has plenty of space around it. The only place that it actually touches anything is the trim around the front fascia, and of course underneath. There is 6” of clearance up top (and a roof vent), nearly 2” on each side, plus plenty of space and vent at the back.
From the same manual you pointed out:
• The following are recommended clearances around the refrigerator:
Sides...............1” (25 mm) Top....................1" (25 mm) Back..................2" (50mm)
Most (small and otherwise) residential fridges are fine to retrofit. When the manual says not to enclose them, it just means don’t put them in a solid box that is flush all around.
44,025 PostsLatest Activity: Feb 18, 2025
