saguaro's avatar
saguaro
Alaskan Camper Accessory Questions
In '99 I bought an 8 ft. Alaskan Camper from the factory and used it extensively for 10 years, selling it when my lady had knee surgery and had difficulty with the climb up to the back door. Not long after I sold it I realized I had made a terrible mistake and began obsessing over another one. Now that the lady is no longer in my life I am about to rectify my blunder.
A few months ago at the factory in Chehalis WA I determined that the 8 1/2 ft. front dinette model would do nicely and selected a list of options. Among them was a $900 awning. I live and boondock often in the Southwest and shade is important. I realize the Alaskan comes with an "awning rail" that allows you to mount a tarp with little brackets, which then must be supported by poles with rope supports attached to the ground but after hassling with that a few times I found it to be cumbersome and hardly worth the trouble. Would like to know if anyone has had experience with this new Alaskan add-on awning and if it is worth the extra dollars.
Also, I like to take along a bicycle when I travel but with the entrance to the Alaskan in the rear directly above the spot where you would normally mount a bike rack, when you are on the road it is necessary to deal with the bike every time you want to get in and out of the camper. I've seen RVers who mount a bike rack on the front of their pickup but I am reluctant to do that. Has anyone come up with a clever way to mount a bike on an Alaskan Camper that would alleviate this problem?
Any other advice or constructive comments regarding the Alaskan would be appreciated. Yes, I know they are expensive, but in the 10 years I owned my previous one I never once regretted paying premium dollars for what I learned is a very high quality product.
Thanks ahead of time for your helpful thoughts.
Saguaro
  • cewillis Just wondering -- has Alaskan done anything about keeping the cabover area dry while the top is being put up or down?
    The cabover side paners fold down and inward laying flat on the bed area. This does help protect the bed around the perimeter untill the top can be lowered.I have found no problem with this unless atempting to do it during heavy blowing rain.
  • Just wondering -- has Alaskan done anything about keeping the cabover area dry while the top is being put up or down?
  • Hi we have a 2007 cab over 8.5 alaskan.IMO they are a very good choice having the hard sides and power hdy.roof lift. If I might suggest the 10 ft. model, I think the extra space would be worth the extra cost.Also ours has the extended cab over which adds a lot of extra space for sleeping and storage,if you have an extended cab truck.We found storage space a bit limited inside so we upgraded to a flat bed with tool boxes under the wings and bed which solved the problem.IMO an upgrade to a compressor frige would be a worth while addition if they are avaible now.As fsr as the awning goes I would maybe shop around and add it my self later,you might find a wider choice of colors styles ect. and maybe save a few bucks too boot.On the bike rack issue, our camper has a factory canoe rack on the roof, you might come up with a plan to adapt it for bikes.Accessing the roof for this is not a problem with top down if one is standing on the truck tail gate or in our case on our floor leavel rear deck.If you have questions just ask.Good luck with your new camper.
    Ramp
  • rottidawg wrote:
    Not many, if any, Alaskan owners here.
    Try here, pop up backroad central:
    http://www.wanderthewest.com/forum/forum/18-alaskan-camper-discussions/
    Not to go off topic but I have long wondered why the Alaskans weren't on this forum. In my opinion they are among the very best of truck campers with a sterling history. You could not make a better choice!
    As to the accessories I think that a front carrier is well worth your investigation. It can hold more than a bike and could come in very handy. They can be made very sturdy. I also second the suggestion for a factory installed awning.
  • I've never had the Alaskan awnings. However, on the motor home, the factory awnings worked much better than my home made ones. Worth the money for sure, especially if you are heading to the SW.
    +1 what Buzzcut said. Get yourself a swing away bike rack. We are on our second. Great tools.
  • Bikes and their racks are relatively light. If you don't want to go the front rack there are two easy options.
    First is a swing out rack. pull a pin and the rack assembly pivots 90* out of the way.
    Second is to put on a hitch extension and move the bike further away from the door.
