anode out?
swtgran
Does anyone just leave their anode out? It seems like it would be better not to have that thing disintegrating in the tank.
Swtgran
2007 Casita 17ft SD
2005 Toyota Tundra
16 REPLIES 16
mlts22
Central TX water tends to be hard due to the limestone. This doesn't eat up the anode rod, but it coats it. I am glad I pulled mine because if I camped another six months, the amount of calcium precipitated onto it would have kept it from being removed. Ironically the rod was almost completely intact with some very slight pitting.
ThorResidencyNe
I just replaced the anode rod in my suburban tank today. Wow, was I surprised by it's condition. I've only had the RV for about 3 months but I don't think it was changed in a long time. The rod was almost completely gone. I also purchased a flushing wand to rinse out the tank. That was a great investment as I spent about 20 minutes flushing out all kinds of "gelatenous" white stuff. At first they looked like white rocks, but they were squishy. It took alot of washing, but it is finally clean. And the best part, the heater seemed to heat the water up much faster once it was clean.
If you haven't ever used a flush wand, try it. You would be amazed at what comes out.
BigDaddyHfx
The obvious answer is leave it in. That's what keeps the water in.
You would need another type of plug but it wouldn't protect the tank. How much does a new water heater cost? Far more than replacing an anode rod every few years I'm thinking.
Chuck_Gail
I never leave mine out. Did you read the post a few years ago where someone left his out and bees used it for a nice nesting place?
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
2010 Outback 230RS Toybox, 5390# UVW, 6800# Loaded
Not yet camped in Hawaii, 2 Canada Provinces, & 2 Territories
I can't be lost because I don't care where this lovely road is going
Mark_and_Linda
I take my rod out when I winterize and drain the tank. I install it loosely after I have done this, just to keep the bugs etc. out. I have a spare one ready the next time I drain my tank.
Mark
Old-Biscuit
It best to drain and flush water heaters routinely.
After draining reinstall drain plug so:
It doesn't get lost
Tanks threads don't get messed up
Bugs/insects don't set up house inside
And water heater is ready to be refilled/used
Anode rods are used on Suburban Brand and NOT Atwood Brand
Replace anode rod when 75% of rod has deteriorated.
HappyKayakers
Jayco23FB wrote:
I drain my tank between camping trips. Camping trips last between 3 and 6 days. Do I need an anode in me water heater?
Only if you have a Suburban water heater and want it to last.
Joe, Mary and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
Jayco23FB
Jayco G2 23FB
2007 Chevrolet 2500HD 6.0L
JJBIRISH
Anytime it is disintegrating in the tank it is only doing the job it was designed to do by being thereโ€ฆ
Love my mass produced, entry level, built by Lazy American Workers, Hornet
bradnailer
If the heater tank has no water in it, there is no value to leaving it out when not in use. The anode only is effective when there's water in the tank.
2013 Jeep Grand Cherokee
2013 Coachmen Freedom Express 233RBS
Prior: Jayco Pop Up, Shasta Bunkhouse, Rockwood Pop Up
beemerphile1
No, I leave it in. The purpose of the anode is to protect the tank by sacrificing itself. I don't understand your thinking. Could you explain?
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
swtgran
Thank you, just what we needed to know.
Swtgran
2007 Casita 17ft SD
2005 Toyota Tundra
Big_Love
If you decide to leave it out when there is no water in tank, make sure you block the opening so insects do not explore your tank.
branson4020
sch911 wrote:
You cannot! Without the anode rod it would be your tank disintegrating. Leave it in, and replace it when it corrodes.
Correct. Any time there is water in the tank, the anode must be installed.
