Kayteg1 wrote:
Now when my build-in Generac died and even new $350 board is not fixing it, I am researching more reasonable option.
$500 inverter generator have excelent reviews and some say it runs smaller AC just fine, but forum search shows 0 topicks.
Hard to believe nobody from the forum tried it?
I own both the 2000 watt HF gennie you reference here, and a 4000 watt HF gennie.
I'll live dangerously and make a blanket statement; the 2000watt HF inverter generator won't power your a/c. It won't power my Dometic a/c even, when it was direct plugged into the a/c unit (testing it before I mounted the Dometic a/c on my TC)
Further, the 4000 watt HF gennie is a red herring WRT being "4000 watts". The way the 4000 gennie works with it's voltage regulator to regulate power, it splits the armature into 2 halves of power - i.e. 2 separate 2000 watt circuits that the ARE OUT OF PHASE with each other so you can't easily combine circuits to make that power an a/c either.
You could buy 2 of those 2000 watt gennies and do this:
Predator Parallel CircuitGood luck in your pursuit.
