Mike E. wrote:
"OP......
What is the exact truck model? (other then '14 Ram 3500) "
It's 4X4 SXT (ST with a few goodies) short box.
And the lowest point of my garage opening is 78".
Well if it's a ST then it already has 17" wheels I think. You could downsize the tires to get you about an inch or so.
No easy way to lower the front. If the rear has a spacer block, remove it or can remove the main leaf (reduces capacity though).
78" seems low for a standard 7' garage door opening. Anything you can do about that?
What's in the way at the low point?
