- LwiddisExplorer IIHalf ton, three-quarter or one ton?
- LwiddisExplorer II1300 to 5200. Page 22
https://www.xr793.com/wp-content/uploads/2017/07/1994-GMC-Sierra.pdf - jaycocreekExplorer IIYou didn't say if it was 3500 or 2500 SRW or DRW but my 1994 ford f350 drw payload is 4600 lbs.
- Grit_dogNavigatorConsidering those were made in 1/2T, 3/4T, 1T SRW and Dually models all fitting your description, I'll say about 1500-4500lbs if you go by the gvwr.
- towproExplorersearch internet for what is payload of 1994 gmc 2500 extended cab
2084 lbs - MORSNOWNavigator IIJust over 2,000 lbs, those older truck just didn't have the payloads of todays trucks.
- Grit_dogNavigator
Not to the OP's query, which was super vague anyway, but while you're correct, that new models and subsequent past models for the last 20 years have all been increasingly stouter (not just axles), my old 86 GMC 3/4 ton, even with the "less desirable" 14 bolt semi floater rear axle is 8600 gvw and 6000lb rawr. On a truck that is about 5000lbs empty curb weight and maybe 2500lbs on the rear axle.
Add it up and payload, by the numbers, has not really increased measurably, or actually has gone down (by the "numbers").
"By the numbers" the old 86 has about 3500lbs of available payload and a set of rear springs that shame most new 3/4 tons. Also rides like a brick.
I've put 3000lbs of material in the back of it and it didn't hit the bump stops.
That said, other advancements in braking, power, frame/chassis rigidity, towing capability, etc have improved immensely in the last 20 years. But basic payload capacity in srw trucks has not increased much, if any. - notevenExplorer IIIThanks for the info everyone.
- JIMNLINExplorer IIIone thing that hasn't changed much is a 3/4 ton trucks rawr payload which will be carrying most if not all of it.
My old long gone '90 450 2500 chevy 2wd long bed had a 60xx rear axle/tire load rating. If I remember right the truck rear axle weighed in the 2650-2700 lb range leaving around 3100-3300 lb in the bed payload.
The 6.5 diesel sits on the front axle so not much difference in rear axle payload.
Keep in mind my truck was current back then and new springs/running gear. A '94 is 27 years old and probably the springs have flattened out some.
A - Grit_dogNavigator
Glad we could be of service...
About Travel Trailer Group
44,029 PostsLatest Activity: Jan 20, 2025
