โApr-20-2021 05:46 PM
โMay-19-2021 06:09 PM
Avid Fox wrote:
I can carry two group 29s in my AF1150.
Are they worth it?
โApr-29-2021 04:25 AM
Siletzspey wrote:Interesting. We have the same PD 45a converter and get a steady 20-25a of charge current at 13.6v charging our 200ah LifePo4 pack from 10-90% SOC. Get 45a charging at 14.4v from 10-95% SOC.
. . . At ~13.6VDC from my 45A-capable Progressive Dynamics converter/charger with very short 4AWG wiring, my 100Ah x 2 BattleBorns at 50% SOC choose to pull ~4A total. At 13.6VDC, their thirst for current is minimal . . .
โApr-28-2021 09:06 PM
โApr-28-2021 08:19 PM
FWC wrote:This is why Elon is so successful. He goes right to the solution. Engineer the product direct to the needed parameters. No hundred year legacy to adapt.
Maybe third time will be a charm for Progressive Dynamics?
โApr-28-2021 06:46 PM
โApr-28-2021 06:09 PM
โApr-28-2021 05:52 PM
Durb wrote:Yes, Battleborn may "recommend" the Progressive Dynamic single-stage 14.6v Lithium charger, but they qualified that recommendation when I called them a year ago. They "suggested" the PD Lithium single-stage 14.6v converter/charger not be connected to their battery for more than 2 weeks *if* it wasn't being used/discharged during that time. In other words, don't float the BB with this particular converter/charger for more than 2 weeks.FWC wrote:Let me get this straight. Progressive Dynamics, a leader, designed a convertor for lithium batteries that isn't as good for lithium batteries as their non lithium convertor? What if I just unplug the convertor between trips, say three weeks? I do disconnect the battery during the off season. I wonder why Battle Born sells my exact charger for use with their batteries.BFL13 wrote:Durb wrote:
I installed a 100AH Battle Born battery and Progressive Dynamics Lithium Convertor in my trailer. No maintenance, no removing the battery during the winter, no battery tender during the off season. I don't obsess about SOC and all the other stuff in this thread. I just ignore the battery and expect to do so for the next ten years. So far, the battery meets all my needs. So, for me, the lithium conversion was worth it.
If that means you are leaving it plugged in for long periods of time doing 14.4-14.6 after it has been fully charged, AFAIK, that would be against Battle Born's guidelines.
Some say to isolate that PD Li converter from the LFPs soon after the batts are fully charged. You still want the converter on in the RV.
That PD Li converter might have been a big mistake in their rush to have something to sell with "Li" written on it.
Agreed, I have no idea why progressive dynamics thought a constant 14.6V output would be a good fit for a lithium battery. You want to shut this off after the battery is charged, or better yet just use their regular converter, which is better suited to lithium.
โApr-28-2021 05:26 PM
Dodgemahal wrote:StirCrazy wrote:Dodgemahal wrote:
Not putting a DC to DC charger in the system carries the risk of two things. Discharged lithiums can pull max current from your (non smart) alternator which will burn it up and possibly cause a fire. Ending up on the side of the road is a big possibility.
Lets clear this one up before it starts spreading as fact.
The only way this is going to happen is is some one took the fuse out of your charging line for your 7 way. Or if some person who didnt have a clue installed there own because it want a factory option and didnt put a fuse in.
I think most of this stems from the youtub video of a guy hooking a li pack directly to an altnator with large wires and started it up using an electric motor. no fuse now voltage loss and yes it did start stuf burning.
having said that I still would encourage the use of a LFP compatable DC to DC charger and proper wiring to provide the LFP battery its best charging.
Steve
Steve
Well you just reiterated what I was mentioning. The proper way to charge Lithiums (with the truck charging system)is with a DC to DC charger and not unregulated with a smart or dumb alternator. Because the lithium battery will absorb a lot of amps if you offer it up. Not sure what you cleared up though. Facts are what we both stated. So thank you. ๐
โApr-28-2021 01:43 PM
โApr-28-2021 01:34 PM
โApr-28-2021 08:49 AM
โApr-28-2021 08:41 AM
Battleborn wrote:
If you are storing your rv and wish to have it plugged in, we would recommend a float voltage of 13.6 volts. If you have a higher voltage applied in float(such as 14.6) then we would recommend that this be no longer than 3 weeks at a time.
โApr-28-2021 08:27 AM
โApr-28-2021 08:16 AM
