โApr-04-2016 03:32 AM
โApr-04-2016 04:13 PM
GoPackGo wrote:
Can't comment directly, but I have an RDS tank, installed with the RDS gravity flow kit using 3/8 inch line and no solenoid. It takes a long time to transfer 30 gallons of diesel thru that 3/8 inch line.
During those times when I've transferred fuel while driving, it WILL keep up with fuel consumption as I tow, but I generally transfer fuel overnight when I'm finished towing just because it does take so long.
Brewurown - Looks like you used a slightly smaller line. Will it flow enough fuel to keep up with fuel consumption while towing ?
โApr-04-2016 03:30 PM
โApr-04-2016 11:28 AM
RayMc wrote:Brewurown wrote:
I install a valve under the bed. Installed a toggle switch on the dash connected to the switched power. I didn't want the valve on if I should forget to turn off the switch. It's been installed now for almost a year, made 3 trips between NC and FL with no problems. I used this valve:
valve
Could I ask why you chose a 1/4" ported valve? The RDS kit is 3/8" tubing and fittings. Did you support the valve or just let the hose carry the load? I have a new Ford SD with upfitter switches so wiring should be a piece of cake.
โApr-04-2016 11:06 AM
valve
โApr-04-2016 05:30 AM
