Memphisdoug's avatar
Memphisdoug
Auxiliary Fuel Tank Shut Off
I just purchased a used pickup that has an auxiliary tank installed. The aux. tank feeds into the vent line of the truck's main tank. There is a switch on the dash to turn on/off the aux. tank. I climbed under the truck to find out what the switch controls and found this. The fuel comes in from the aux. tank at the top of the picture and enters the two devices shown. The bottom thing appears to be an on/off solenoid but what is the top thing? Both have power from the switch to them.
  • Did 2 aux tanks like that. The small line and an in line filter keeps the flow rate slow. Added an in line pump to boost the flow rate so that it would transfer in a reasonable amount of time.
    +1 on the 1/4 turn ball at the aux tank outlet. Nice if you have a leak or need to pull the tank for any reason.
  • So the top horseshoe shaped black thing is a pump? The guy I bought the truck from said when he switched on the aux. tank it pretty much just kept up with the truck running at 55 mph. I'm thinking a bigger pump would be a good idea so you could transfer faster than you're using it.
  • DirtyOil wrote:
    I have similar set up, although I have a inline filter as well. You have a pump and solenoid valve (that is if that "top" part is between tank and solenoid valve). Also have manual ball valve right at the tank. The pump is on the small side, with a heavy load and strong headwinds, pump barely if at keeps up. Thinking I might find a higher rate pump.
    I have mine running gravity flow and it will run in the tank faster than I burn it.
  • I have similar set up, although I have a inline filter as well. You have a pump and solenoid valve (that is if that "top" part is between tank and solenoid valve). Also have manual ball valve right at the tank. The pump is on the small side, with a heavy load and strong headwinds, pump barely if at keeps up. Thinking I might find a higher rate pump.
