minnow wrote:
GoPackGo wrote:
Diesel - yes ?
I also have an RDS tank with the gravity flow system. They sell an install kit that includes the check valve which stops back flow. There is also a manual on/off valve on the tank. I believe in KISS.
I got the 40 gallon tank/tool box combo which fits below the rails so I can also have a bed cover. If I was doing it over I would get the 60 gallon (?) tank with the smaller tool box. It has the same footprint.
Northern Tool sells them. I suggest going to the RDS site to view all the possible tanks (there are lots). I have even read they will custom make one but have not confirmed that.
Why would you go with the 60 gallon ? I'm looking at the 40 gallon right now.
I had a couple different reasons:
1. I can't get 40 gallons into that tank. Closer to 35. Admittedly not a huge difference but I wavered between the 40 and 60 to begin with.
2. I found I really don't need as large a tool box and could easily get by with the smaller one in the larger tank/toolbox combo, especially since they both have exactly the same outside dimensions.
I bought the tank primarily because I wanted an aux fuel tank. The toolbox was a secondary consideration. I now assume I could only get about 55 gallons into the 60 gallon tank and I'd rather be able to carry 55 as opposed to 35 gallons.
