โJan-24-2016 11:17 AM
โJan-25-2016 05:16 AM
eHoefler wrote:
I have a 70 gph pump on mine, I ran a vent return line back to the aux tank. This helps in 2 ways, air is vented to the aux tank where the fuel is being removed, and for the times I forget to turn off the pump.
โJan-25-2016 04:48 AM
โJan-25-2016 04:23 AM
pressure_welder wrote:
No worries fellas was just curious to see what guys have done out there. I considered gravity feed however it is illegal up here and I require yearly safeties. Plus I wanted the ability to fill quickly and push the fuel through a quality filter. I can fill my stocker in about 3 min. I believe my only option will be to tap into the existing vent line and run a hose back upto the aux tank to one of my spare ports ontop of the tank.... I was discussing with a friend and we figure the vaccume created by the pump in the aux tank will essentially in turn suck The air out that isn't being displaced in the trucks fuel tank via the stock vent tube.
โJan-24-2016 11:18 PM
โJan-24-2016 06:31 PM
lawnspecialties wrote:Bird Freak wrote:
Wish I could help but both tanks I installed with RDS kit were gravity feed. No need for a pump.
Ditto.
โJan-24-2016 05:22 PM
โJan-24-2016 05:04 PM
โJan-24-2016 03:00 PM
โJan-24-2016 11:54 AM
