rhagfo
Apr 11, 2016Explorer III
NJEagle314 wrote:
Hi All,
First time poster here. My wife and I are in the process of a major upgrade from a small 21' non slide tin and sticks Coachmen (being towed by a GMC Acadia), to a brand new 31' Jacyo Eagle 314BHDS. We have purchased a 2002 Chevy Avalanche 2500 as a tow vehicle and I am slightly concerned about the travel trailer being "too much" for the truck.
The TT falls within the capacities of the Avalanche but I am trying to find out if anyone has experience towing large trailers with either an Avalanche 2500 or a 2500 Suburban/YukonXL.
Specs are as follows:
Avalanche 2500
Wheelbase - 130"
GCWR - 17,000 lbs
Curb Weight - 6,642 lbs
3:73 Axle (Tow rating 10,100 lbs - with a 4.10 it's 12,000)
Payload - 1,958 lbs
GVWR - 8,600
8.1 liter (496ci), 340hp, 455 torque
Camper
Jayco Eagle 314BHDS
Dry weight 8,110
GVW 9,975
Tongue 1,065 dry
I realize that with a fully loaded camper we will be getting close to the GCWR, however we will not be traveling with any water or waste in the tanks, and I would expect that we will not be loading the TT with more than 1,000 lbs. My wife and I combined are less than 300 lbs, and we have two small children.
Due to the size of the engine I do not expect any issues with power, I'm more concerned about the size of the camper to the truck. Friends have gigantic 2500 Rams towing the same size camper and the Avalanche looks small compared to these.
Thanks in advance for your thoughts!
The last statement in RED is one I laugh at all the time, I have towed home several time with tanks FULL! Why, no convenient dump stations! Many times over good sized mountain passes!!
If you don't think you can run with full tanks start looking for a bigger TV, with a longer wheel Base!
44,025 PostsLatest Activity: Feb 26, 2025
