LKHA's avatar
LKHA
B and W companion hitch
Pro/cons? Will be installing in 08 chevy 3500. Anyone know what holes to use when setting it up?
  • I've had B&W hitches in my last five trucks and one Companion. Hands down the best hitch on the market and best customer service in the industry. One draw back. The hitch will not tow rigs with the older style Sidewinder pin boxes that have the "wedge" behind the pin.
  • Long bed place head supports closest to cab with straight edge closest to cab also. Height, do some math!
    B&W is the GOLD standard in non air ride hitches. Simple solid no question if you are hitched US Made.
    Base is a bit different than your application.
    For some peoples viewing pleasure. :)
  • Pros: Excellent hitch, easy to use, pretty much impossible to screw up when hitching.
    Cons: None that come to mind.
    As far as the height/holes, it just depends on your truck and trailer.
