ib516
Jul 14, 2017Explorer II
Back into a truck - UPDATED with pics (Sept 19)
Many of you may know - I went through a nasty divorce over the last two years. I lost my RV, and had to sell my 2014 Ram 2500/6.4L Hemi to pay for child support/bills/moving expenses/etc. Well, that's all done with now, and I'm beginning to live my life again. I met a new gal, and she bought the 2010 Jayco 17z in my sig (3500# (GVWR) 17' hybrid TT). I had pulled it short trips/locally with a 2006 AWD Pontiac Torrent that I added a hitch, wiring, and a trans cooler to. It did surprisingly well, but had a saggy rear end when towing. But, we have 3 weeks in the Rockies booked so...
Well, the other day, while browsing the local classifieds, I came upon a high mile 2006 Chev 1500, 4x4, 3.73, Ext. cab short bed. It's rough, but it was cheap. It had a 4.8L from the factory, but somebody swapped in a 5.3L. The chassis has 230,000 Km on it (~144,000 miles), and I have no idea how many miles the 5.3L has on it, but I was told it has less - around 100,000 miles. The truck has rubber floors, crank your own windows, but it has AC and cruise and a 4L60E auto.
Payload is 1245#, and it has the G80, locker in the rear, Z82 and Z85 towing and HD suspension options, and skid plates. I found the original window sticker in the glove box.
It has some surface rust on the rockers and above the rear wheels.
Soooo......I have some work to do. I'm going to be swapping out the accessory drive and AC belts, tensioners, and idler pulleys, shocks, and ignition switch tumbler this weekend. It has a new exhaust, but one broken stud - driver's side front. Deal with that later. I'm also doing an oil flush/change (dump in flush solvent, idle, drain, refill with new oil). The ABS has been disabled (LF speed sensor/hub throws code), but the AC, cruise, and 4wd all work.
Seems to run OK other than the above issues. I'll keep you posted.
