pjay9
Sep 15, 2014Explorer
Back-up cams
I have been reviewing many of the posts about the new wireless cams. As I have learned they all require power to fire up the camera and many have hooked them the the clearance lights...this is a good idea..you want cam turn on lights...VOILA!!!
Now here's another thought...my Lance was prewired for a wired back up cam system, which I know is not what the new technology is today. I can see using it not just for backing up but for passing other vehicles and just to make sure the boat is doing fine and also hooking up to the trailer single handed. Don't really want it on all the time.
So two ways to look at it: (I bet there will be more posting about that) 1. Find a wired system and install it, don't really fancy all the wire work in the truck to do this, but it can be done. I assume the viewer head would control the cam on-off function. 2. Use the wire harness to supply power to the cam, but then how do I turn it on and off from the cab?
Other thoughtful and provocative suggestions always welcome.
