Caboose66's avatar
Caboose66
bar size for Equal-i-zer hitch
I have done some seraching around and am not finding quite what I'm looking for with regards to an answer to this question:
I am purchasing an Equal-i-zer hitch. The published (dry) tongue weight is approx. 700#. I know that, after strategically loading the trailer, this will increase some. My question is, what size (capacity) hitch would you get? I know that bigger, i.e. higher capacity, isn't better necessarily as it affects ride quality if you're significantly oversized.
At first blush, I can likely get away with the 1,000# version, but I am thinking it might be better to go up to the 1,200#. Would you go any higher than that? I can go up to 1,400#, but that seems like it's getting into the negative ride quality area.
What's your experience and/or advice?
Thanks, Dean
