Battery charger life span
mattyj
I'm wondering how much longer the life on my charger will last. It's 12 years old now , anyone had an experience with a dead charger due to age? I'd appreciate any input , thanks LOU
2006 Ford F 350, 6.0 PSD 8 Foot Bed 4x4 with Torklift Tie downs ,Stable Loads ,rear Helwig Swaybar,airlifts 5000 , Method 305 HD rims . 2019 Adventurer 89 RBS, slideout, Generator
15 REPLIES 15
Old-Biscuit
SidecarFlip wrote:
I believe RV builders install WFCO's because they are cheap....and they are cheap and cheaply made, but then a lot of RV factory installed stuff is cheaply made like the fake chrome plastic faucets and crappy shower heads for instance.
Now see..you really didn't disagree with me :B
SidecarFlip
time2roll wrote:
SidecarFlip wrote:
.... according to my SeeLevel battery monitor my cheapazz WFCO charges at 14.4 and drops to 13.2 in float mode all the time.
If it works, don't screw with it.
I agree yours would seem to be one of the few that works. By all means keep it.
Neither of mine have performed even close to what I expected. Plenty of posts with similar issues. The fact that WFCO full-on dies more often is probably accounted for that there are more WFCOs in use.
Sorry to drag this thread off track ๐Ÿ˜‰
No issue with me.
My next one will be a PD no matter what. I like to support in state businesses whenever possible and PD is in Marshall, Michigan just off Michigan Avenue, been past it many times.
Heck, even the ancient Magnatek I had in my Lance, always worked. Those are real rocks.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
time2roll
SidecarFlip
While I don't normally disagree with Mr. Biscuit I will say that according to my SeeLevel battery monitor my cheapazz WFCO charges at 14.4 and drops to 13.2 in float mode all the time. I haven't had to water my batteries since April either.
Like I said, when it goes south, I'll replace it. Until then, it stays.
My credo is... If it works, don't screw with it.
time2roll
It is not my criteria. It is the standards in the WFCO brochure and specifications.
It is like a car that only operates in second gear. Sure you get there and maybe a few are happy.
Bumpyroad
time2roll wrote:
Based on two WFCOs and confirmation hearsay.
If yours works for you fine and you must be OK with a basic fixed voltage supply.
Otherwise does your WFCO charge at 14.4 volts when your battery is low?
And does it actually drop to float 13.2 in a couple days of minimal use?
I have no idea if my battery chargers meet your criteria. I do know that they have served me faithfully for many years, even if they are defective according to your standards.
bumpy
time2roll
SidecarFlip wrote:
time2roll wrote:
If it is a WFCO it was already defective right out of the factory.
Most of the others will continue to be reliable.
Interesting and obviously biased comment, most likely based on hearsay rather than experience.
Mine works fine and has for a couple years now.
When it pukes, I'll replace it with a locally made Progressive Dynamics.
Until then, I see no need to spend the money.
gbopp
Bumpyroad wrote:
mine last until the kids leave them out in the rain.
bumpy
Yep. That's about the average life span of a lot of tools.
Old-Biscuit
Sorry but WFCOs are junk....one of the least reliable converters but used by many RV Mfgs (cause they are cheap)
SidecarFlip
time2roll
Old-Biscuit
Asking about the charger as in 'converter'??
Better ones available...true 3 stage charging and not that expensive
Best Converter...ASK RANDY!
Bumpyroad
bumpy
jimh406
There's really no way to predict how long it will last. I'd leave it as long as it works ok.
